The SAT didn’t sound right on the AS at tang’s. It sounded right on the Techdas. Overall, I too did not find anything particularly better with the SAT Opus that was more musical. And staying with the SME seemed the logical choice. I don’t like the axiom either.
but that is like comparing a Devore or Martin Logan hybrid to XVX or Rockport. I prefer the school of Devore or MLs, does not mean there are not better speakers in that school of thinking. I definitely see no reason to buy a SAT over an SME, but there could be other arms, and certainly there is an arm cart synergy with no universal arm.
I would assume that customers for The Absolute Nothing are likely to buy into the philosophical approach to the high end that comes with it as well. This will limit ventures into pairing with other design approaches.
Assumption Al , if DDK had such a strict limited vision/ approach he wouldnt sell the TT with 4 armboards.
It only adds cost
They are all SME armboards.
Are there any pictures of the pump box?
If I were buying a turntable of this caliber, I would be buying the designer’s design philosophy, as well as his skills and ears in tuning the sound of the final products! So, if the designer highly recommend a particular arm, I trust there must be certain synergy between the two products, and I would certainly install one on the turntable as a reference.
Of course, since 4 arms could be installed at the same time, I would also try other arms to find the best combinations to my ears.
And I think this was after having the Axiom set up properly by its designer, though it might have been the SAT.
Many people have seen how I have been keeping the SME playing with the vdh while other modern arms kept leaving my arm base.
...me too. And I don't even own a TT.I really miss having Tang on the forum.
There is not much more to learn or discuss here.
Why does the 3012 seem to be the right choice?The SAT didn’t sound right on the AS at tang’s. It sounded right on the Techdas. Overall, I too did not find anything particularly better with the SAT Opus that was more musical. And staying with the SME seemed the logical choice. I don’t like the axiom either.
You usually write a lot about tonearms and are very clear about which arm is good - better - best with which cartridge. Why should the 3012 be absolutely top on the AS?
What don't you like about the Axiom? Some people would swap their favorite lady for it!![]()
