Yes, Taiko is talking about the best connection into its Switch, and it recommends ethernet over fiber. But you may be right that noise could be further reduced by, for example, implementing your suggestion of router > fiber > OM > good ethernet cable > Taiko Switch. Indeed, I have a second system at another house that basically uses that topology, but with an ER as the switch. I'll be putting the QSA Lanedri DC cable to use in that system and will report later.Bear in mind I suspect Taiko is talking only about the SFP v RJ45 noise, and no the cable going into the RJ45. I wonder if 60 feet of wired ethernet cable will shunt more noise in than a SFP makes.
If it could be achieved without breaking the bank (or house) I suspect the better solution would be ...
router > fibre > OM > top grade ethernet cable > Taiko Switch > and so on.
or
router > wifi > Wifi Access point > top grade ethernet cable > Taiko Switch > and so on.
That is very promising to hear. In your case perhaps it is so significant because the router is not powered via a dedicated AC supply or power conditioner. For example, I have my router in the hifi rack powered via dedicated AC, a power conditioner and decent LPS, all grounded with a very good grounding system ... but basic DC cables from audio manufacturers.
As for whether the impact of the DC cable on my router is significant because the router has not already received the deluxe treatment (as yours has), I can't say from firsthand experience. But from all my experience with QSA cables (power, interconnects, speaker, and now ethernet in different systems), I fully agree with @QSA-LANEDRI that huge gains are possible WITH deluxe treatment already in place.
Thus, once my digital audio signal reaches my Extreme, I've got an extremely (pun intended) transparent chain -- and yet, the various QSA cables I've inserted have made worlds of difference. In fact, I suspect that the more transparent your system already is, the more apparent the gains from QSA'd cables will be.
