Yes the main thing that matters is which one sounds more natural, that's number 1 IMO and I am attributing the unnaturalness in 2 & 3 to the mics.
1 and 2 used the same mic (iPhone internal mic)
The same model of iphone?1 and 2 used the same mic (iPhone internal mic)
The question is not more or less natural the question is which one sounds like Ron’s system if you are sitting there in the room?
Even when it’s true? (Not saying it is in this case)
Is it likely to matter?
blog.faberacoustical.com
Criticize the words, the description, not the man.
I, personally, find the David/Tang speaker video to be comparatively low in resolution and transparency. Peter, I don't understand how you find that video abundant in "information" and "nuance."
The MV88+ video reasonably fairly represents the in-the-room resolution I hear. The iPhone mic video reasonably fairly represents the tonal balance I hear in the room.
mynewmicrophone.com
Yes:
iPhone Microphone Frequency Response Comparison
With the advent of sound level meter apps for the iPhone OS (of which SoundMeter was the first) people began to ask, "How flat is the frequency response of the iPhone's microphone?" Early testing indicatedblog.faberacoustical.com
This is measuring an old iPhone model. I can't imagine that if David and I have an iPhone that is no more than one (1) generation apart that the microphone frequency response is going to materially different.
www.dxomark.com
Not debating that…questioning if the Shure is the right tool for the job…Of course, you are correct, and we can't know that, which is why it is best to use higher quality recording equipment...
But we can also try to make an evaluation of the end result compared to the original track. If that were not the case, would you (or anyone else, including myself) be posting videos on YouTube?
My only reference, as a viewer, is to compare the video to the original track.
It is a very difficult excercise, and I think I was very careful in pointing out potential limitations of the recordings (of all three videos).
Which is precisely why I put forward the iTestMic2 in that any inconsistency between disparate chipsets , circuits and mic’s across iphone and Android are rendered moot, and we might have that ’standardisation’ talked about , the hardware at least.Yes:
I too find that recording lower in resolution and dare I say muddy . Voice and what is being sung is not so easy at times to clearly hear. Is the tone nice? Yes but at least as recorded it throws the baby out with bath water. Tone and dynamics, sure, but there also needs to be transparency and resolution…the other way around(more common in high end) is also not good as it comes across as analytical and unnatural.We don't share the same values.
I think your judgement here is clouded by the idea you have of what the systems should sound like, and perhaps even by Ron's own comments on his video which need to be taken with a grain of salt as he is not - correct me if I am wrong - listening with headphones
Given the poor quality of the video 1, I don't see how you can say that it sounds more natural (unless you think colored sound is more natural).
Once again, I was not criticizing Rexp, I was just trying to offer explanations... Why are you being so insistent about this ? Did I offend you in some way ?
I don't see how one can conclude that video 1 is more "natural sounding" than 3. The sound quality of the recording of video 1 is bad, there is echo, coloration, etc.. comparing with the original track played from Qobuz makes it very clear.
