Have you listened to any of the Dalby Audio footers under electronics? To my ears they surpass both CMS and Stillpoints. Haven’t heard a Stillpoints footer by the way that didn’t impart a slight hardness/sterility to the sound. In my opinion no “stationary” chassis contacting vibration absorbing/dissipating footer (e.g., ASI, CMS, Dalby, Stillpoints, Wilson, RevOPod, etc.) provides the benefits of combining such footers with a movement based device (e.g., Townshend, Wellfloat). This is particularly true for speakers but applies to electronics as well. Such combinations are commonplace among the system photos at Audio Exotics, and my own experience bears this out.ive used sp mini v2. ss ultra. ultra 5. cms .8
stillpoint clean up the sound more detail tight even slightly sterile if used on the wrong component.
cms adds more relaxed bloomy wooly warm. less detail more tone easier to deal with bit more fun but less accurate.
i use cms under my gigawatt pc3 se evo
stillpoint under sbooster power supply bonn n8
merging power player stack and vitus sia 025
ultra 5 is my favourite footer is best of both world bass and detail.
the search continues
I experimented with steel points in my system years ago and then I heard them again under our friends CD player last week. I completely agree with your assessment that they impart a slight hardness and sterility to the sound. As soon as we removed them, the sound became more natural.Have you listened to any of the Dalby Audio footers? To my ears they surpass both CMS and Stillpoints. Haven’t heard a Stillpoints footer by the way that didn’t impart a slight hardness/sterility to the sound.
you might want to have a listen too the new Ultra TT Center Stage footer. As for Stillpoints... They rob the system of ambient sound with a complete loss of presence. There is no comparisonHave you listened to any of the Dalby Audio footers? To my ears they surpass both CMS and Stillpoints. Haven’t heard a Stillpoints footer by the way that didn’t impart a slight hardness/sterility to the sound.
Interesting...my favorite footer is using an HRS Nimbus Coupler (elastomer on both sides with metal inside) sitting ON TOP of the Stillpoints Ultra 7 as a single combination. I place the component on top...and it gives all the detail, discernment of Stillpoints but you get brilliant tone/depth of HRS with none of the slightly hardening of the sound, potentially slightly sterile treble that some have heard (including me) of Stillpoints.ive used sp mini v2. ss ultra. ultra 5. cms .8
@PeterA. with all due respect your friend heard a beta version of the initial CS footer prototype over 4 years ago. If you want to comment, kindly give proper current information (which you don't have). You're comparing apples to anything but the same
I also had SP's in my entire system and was mesmerized by them because of the way sound came and went out of darkness. The reality is that that is not the way we hear. IMHO ambience with SP's does not exist at the expense of black background and as a result for my ears there is a complete loss of presence. This for me is a deal breaker. Can someone explain to me how Stillpoints work. Is there some law of physics under which they function? I am not sure. However I can tell you under what Law of Physics Center Stage footers are designed around
...truer words have never been written. I am reading this with morning coffee, ridiculously agile hummingbirds at the feeder, sun rising over Gila NF, all courtesy of "the Laws of Physics." I loves me some physics!Everything operates under the laws of physics.
how do you decide which cms footer to use. 0.8, 1.0 or 1.5? Or do you simply use 1.5 for all of your gears?FWIW all of my front and rear ended components are sitting on CMS racks and each component sits on CS feet which sit on the CMS racks.
I use Ultra TT under all my electronicshow do you decide which cms footer to use. 0.8, 1.0 or 1.5? Or do you simply use 1.5 for all of your gears?
Yeah I saw that in your new post. I’ll probably have a look at TT instead of 2M.I use Ultra TT under all my electronics
Nor am I a physicist. The design of the "technology pocket" of Stillpoints Ultra products has evolved over the years. The design goal being to create a non-straight, confused path for the physical/mechanical vibration to travel resulting in that vibration dissipated as quickly as is possible as heat....
As far as how Stillpoints function, they turn physical/mechanical vibration from a component into heat. I am not a physicist ...
I agree completely.Everything operates under the laws of physics.
As I recall and checked to verify, Joe L. stated the Second law of Thermodynamics, which says that electromechanical and dynamic systems like audio components reach a state of disarray after some use, which he rectifies (for lack of a better descriptor) resulting in better sonics. There are many more details available along that result in his secret sauce. You can call that "marketing", I personally find it refreshing when designers give specifics as to how they achieve what they do. The alternative which we see via many companies is to state nothing.As far as how Stillpoints function, they turn physical/mechanical vibration from a component into heat. I am not a physicist but the First Law of Thermodynamics (put in caps to make it look important) which is a restatement of the law of conservation of energy is probably what you're looing for. The whole "Law of Physics" thing with Center Stage strikes me as marketing. Everything operates under the laws of physics.
simply put Joe's CMS racks function under First Law of Thermodynamics and his footers function under Second Law of ThermodynamicsAs I recall and checked to verify, Joe L. stated the Second law of Thermodynamics, which says that electromechanical and dynamic systems like audio components reach a state of disarray after some use, which he rectifies (for lack of a better descriptor) resulting in better sonics. There are many more details available along that result in his secret sauce. You can call that "marketing", I personally find it refreshing when designers give specifics as to how they achieve what they do. The alternative which we see via many companies is to state nothing.
I wish there was an easy way to rectify my own state of disarray! My wife would appreciate if my “sonics” were improved, though she might opt for a “black background”, natural or not.As I recall and checked to verify, Joe L. stated the Second law of Thermodynamics, which says that electromechanical and dynamic systems like audio components reach a state of disarray after some use, which he rectifies (for lack of a better descriptor) resulting in better sonics. There are many more details available along that result in his secret sauce. You can call that "marketing", I personally find it refreshing when designers give specifics as to how they achieve what they do. The alternative which we see via many companies is to state nothing.
You and me both my friend!I wish there was an easy way to rectify my own state of disarray! My wife would appreciate if my “sonics” were improved, though she might opt for a “black background”, natural or not.
