Hi all,
Some of you may know me as a DIYer from other forums. I am here today to report my spectacular experience in adding the QSA Lanedri Gamma Revelation PC and Gamma Revelation XLRs to my system.
What did I replace and where (in the end)?:
1. Furutech DPS 4.1 between the wall and my Uberbuss power conditioner, with Fi-50 NCF series connectors.
2. DIY single helix Mundorf Angelique XLR cables between the DAC and my preamp. (Later, the DIYs were moved to between preamp and amp and i'll talk about what those replaced later).
So where did I begin?
1. Swapping the VH Audio Flavor 4 PC with Parts Connexion Rhodium plugs on my server LPS.
2. The Viborg vp1501 with Wooden bodied/rhodium plated plugs from Aliexpress feeding the DC4 powering my JCAT USB XE.
3. Replacing the Furutech DPS 4.1 with Parts Connexion Rhodium plugs I use on my Yggy Lim Dac.
4. Replacing the Furutech DPS 4.1 with Fi-50 NCF connectors at the wall feeding my power conditioner.
The first swap, I noticed an immediate drop in the noise floor and a notable improvement in subtle detail expression. This was wonderful but it didn't "wow" me although I knew there would be plenty of potential there that would unleash itself over time. I decided to try my luck on the DC4 powering my JCAT USB XE and this blew my mind. I could not believe the improvement in dynamics, openness, reduced noise floor and slam. It was like a huge veil had been lifted but it did seem a bit imbalanced/exaggerated although really fun. Worth noting the above tests were conducted several days into my journey and I had not yet installed the Gamma Revelation XLR cable.
Over the course of several days, the sound quality became more natural and refined, with even more resolution coming through than I ever thought possible of my system. I decided to move the Gamma revelation PC even closer to my DAC (which uses a QSA Violet fuse), and this swap unfortunately did not go as planned. Mind you, this is early on in the journey of the power cable's life (several days in) and I quickly came to the conclusion that I missed the body and presences of the DPS 4.1 although resolution had gone way up (this is on the DAC). I did not have the patience to leave it there, so I replaced the Furutech DPS 4.1 at the wall, feeding my power conditioner (I plug my amp directly into the QSA Red receptacle at the wall FYI) and I have not been able to remove it. This is where I think I will keep it. It sounds AMAZING feeding the Uberbuss.
The moment the Gamma Revelation was installed at the wall, this was the moment I think I finally got a taste of what everyone had been sharing. The sound was so dynamic, transparent, natural and pleasing to the ear. I just can't wrap my finger around the words to describe how positively impactful this swap was. I was not prepared for this positive impact and I am now trying to figure out how to purchase the Gamma Infinity to replace it so that I can move this Gamma revelation elsewhere (eyeing the preamp which I have yet to try). So needless to say, I have not moved the cable from this position and I have no plans to move it until I can upgrade it.
Since it is incredibly difficult in my room to swap XLR cables, I left this for last. I had been using AudioEnvy O'Nestian XLRs between my preamp and amp for a while now. A nicely priced and excellent sounding IC. Unfortunately it held back the Gamma Revelations that were installed upstream. The impact of installing the Gamma Revelations between the dac and preamp was most definitely muted until I moved my DIY cables back into my system. The level of realism and presence I am experiencing after these cable swaps is truly astonishing. I am not really able to describe this profound improvement. I like to think of the addition of QSA cables as removal of various bottlenecks which were limiting my system's potential, allowing my system to reach a level I did not know possible.
Hopefully this post was simple enough to follow!
Cheers,
-Rob
Cheers,
-Rob
