1. Mine is!!
2. What struck me as odd though is that DartZeel measures better in single-ended than balanced.
1. Wise axe!
2. I am not.
1. Mine is!!
(...) Ask any conscientious preamp designer, and the less parts used in a preamp the better it is for a lot of things, including sound quality with less extraneous sound introduced in the signal path.
Besides, well designed single-ended products are less expensive (in general), because they use less parts indeed.
And there is simply no such thing as parts that have no sound. (...)
Bob,
Surely the many designers of non balanced preamplifiers do not agree with you.
In your analysis you are forgetting the importance of power supply in most designs - some designers even say that the power supply is 90% of sound quality. The power supply in non ideal, and its "faults" leak into the audio circuit output.
As it leaks in similar ways to both phases it is a common mode signal and can be eliminated easily by subtraction at the input of the receiving device. Common mode distortions can also be cancelled. We may consider that as the designer does not have to think about this common mode problems, he is free to use simpler circuits with better sound.![]()
All solutions have pro and against - there are no clear winners in these matters.
But going Balanced is still a solution looking for a problem.
Balanced just adds complications to the design.
I don't agree with your statement one bit. Balanced audio was a solution to a very real problem in recording studios where long cable runs and hum were a real issue. If they didn't have benefits for regular audio systems, we wouldn't see them being used.
You keep touting the odd-ball gear that measures better in unbalanced mode than in balanced mode. I could be wrong, but I think these are the exceptions and not the norm as by design, the balanced gear should have better measurements. Balanced gear is typically more quiet and has more gain than single-ended circuits which is usually highly desirable. Is balanced gear more complicated? Yes. Does it have real world benefits? Yes.
Hmmm... If the design uses op-amps, balanced may require extra components. If discrete, the number of components should be essentially the same, and the differential (balanced) design should offer better rejection of even-order harmonics and higher CMRR/PSRR. Most of the discrete SS preamps and almost all power amps I have seen above the very cheapest use balanced circuits internally, converting at the input stage and switching back to single-ended at the output stage. That said, I admit that relative to most of you I have seen a relatively low quantity...
Since gain is effectively doubled using a differential design, noise should be a wash, or in fact just a little better since it goes by square root and gain linearly, IIRC.
In my previous life, virtually all my designs were differential, but they were not audio.
Conrad-Johnson?
Thanks Bob. I've been lurking for awhile, soaking it all in and becoming familiar with the cast of characters!Bill, great post! And welcome to WBF! :b
Bob
--Bill
There seems to be some confusion or misunderstanding of balanced inputs and outputs. (...)
--Bill
Microstrip, I was using the terms specifically to describe particular behaviors. And to point out the fact that a 'balanced audio' IC and input was a different animal from a 'differential signaling' IC and input, though a properly designed IC and input stage can (and should) be both. In the real world with the IC's and associated equipment we are offered, they are frequently not working as you'd think regardless of how those 'features' are promoted by the manufacturers, particularly in the case of IC's.Bill,
Thanks for posting a summarizing report on the balanced versus single ended debate, but IMHO, your free use of the balanced and differential words isolated or taken out of the normal expressions "differential signalling" (transmission of signals using complementary signals) , "differential input" or "balanced audio" risks to confuse our non technical readers.
Is there any such thing in analog audio?. With a properly designed balanced differential input stage and (twisted pair) IC the common mode rejection is significant, to 60db or greater rejection of the common mode signal.We should remember common mode rejection is not an ideal property in real world - rejects anything in common is not true - it is why we have to deal with input stage common-mode distortion
I admit this would be vague to some readers. However I did refer to power supplied to each device, and with that comes grounding, in combination with inter-chassis connections of shields or additional return lines, including AC grounds. That provides different, multiple, returns paths for a given input, and was my point.Also, you appreciation of the balanced mode versus unbalanced on terms of because it treats the signal lines differently. completely ignores the grounding concepts . its problems ans solutions in single ended mode.
As do I. My post was not intended to include this much additional detail, only to point out the basics and the need to differentiate the two concepts.I suggest our readers interested in these features go to the sources:
http://en.wikipedia.org/wiki/Balanced_audio
and
http://en.wikipedia.org/wiki/Differential_signalling
There may be an occasional combination of equipment that could produce results close to a truly balanced system (there I go again, tossing incomplete terms around). The differences may be subtle, but still there. I believe you have to treat both + and - signals identically to achieve that final level of transparency, not just tie chassis together with a common ground.BTW, my current equipment is balanced - but I do not have any preference in this mode, I know of comparable performance systems that are single ended!
It is not difficult to make a twisted triad which maintans a constant impedance on all three wire combinations. For example, 100 ohms + to - and 100 ohms each to "pin 1". All one has to do is maintain insulation contact between all wires. Twisting with a drill will not do that, as the unwrap will open the spacing. Hand twisting, or machine where the spools counter-rotate can do this also.Of possibly greater significance is the IC itself. A traditional balanced IC is a twisted pair inside a tight shield, as this is the easiest way to maintain a constant impedance from end to end. A so-called balanced IC that is unshielded and simply connects pin 1 to pin 1, pin 2 to pin 2 and pin 3 to pin 3 on the XLR ends, is NOT balanced. This is a worst case IC because not only is it not shielded (or is shielded in total, not just signal pins 2 and 3) its signal runs (pins 2 and 3) are not impedance maintained. Therefore at the balanced input its performance is anybodies guess. An unshielded IC with pins 2 and 3 wiring carefully impedance matched end to end MAY have pretty decent characteristics at a --Bill
