Just acquired one of these. Would like to seek advice from fellow members what is the besting loading for this cart. Thanks.
I've heard it and as I recall the best sound was about 100 Ohms, but I can't recall the exact value. It's a stunning cartridge, I enjoyed it very much. It depends a little bit on your cables too, so don't get stuck on one value and play around.Just acquired one of these. Would like to seek advice from fellow members what is the besting loading for this cart. Thanks.
I've only heard the Phasemation EA-350, which I have here and is excellent, but even more so when used with the T-1000 dual mono SUTs, instead of the EA-350's internal SUTs. François at Ana Mighty Sound says the EA-1200 is pretty special, even if the EA-2000 is clearly better. I am in awe of the physical quality of all Phasemation products, which are truly high-end at mostly sensible prices.Thanks for the insight. I am waiting for my arm base for Groovemaster III. Will mount the PP-2000 on this arm. @Shuggie, I am also exploring their Phono stages as well. I heard the PP-1000 on their EA2000 6 chassis phono. Very nice. However, 6 boxes is too many a box for me. No space on the rack
EA-350 is a great phono stage, but it doesn't use SUT. It has a separate input stage for MC which is a voltage amplifier, so you can think of it as a solid-state replacement for SUT. I could live with even EA-200 and PP-200, they make a killer combo for a reasonable priceI've only heard the Phasemation EA-350, which I have here and is excellent, but even more so when used with the T-1000 dual mono SUTs, instead of the EA-350's internal SUTs. François at Ana Mighty Sound says the EA-1200 is pretty special, even if the EA-2000 is clearly better. I am in awe of the physical quality of all Phasemation products, which are truly high-end at mostly sensible prices.
Sorry, but that is wrong. The EA-350 does have internal SUTs, clearly stated on their website https://phasemation.com/product/ea-350.html :EA-350 is a great phono stage, but it doesn't use SUT. It has a separate input stage for MC which is a voltage amplifier, so you can think of it as a solid-state replacement for SUT. I could live with even EA-200 and PP-200, they make a killer combo for a reasonable price
Last year, using our knowledge gained from making T-2000 which sparkled having won many awards last year, we built in a step-up transformer with a special split winding structure supporting balanced transmissions of a 26dB gain and this makes an MC balanced transmission.
may be he mixed it up with EA-320, which is a non SUT concept.Sorry, but that is wrong. The EA-350 does have internal SUTs, clearly stated on their website https://phasemation.com/product/ea-350.html :
Yes, you are right. I have seen the wrong product photo. It's a stunning phono preamp anyway. I could easily live with it!Sorry, but that is wrong. The EA-350 does have internal SUTs, clearly stated on their website https://phasemation.com/product/ea-350.html :
I like the idea of having two cartridges. One high-end MC for the ultimate musical engagement and one solid MM for having fun with records of lesser quality.Very tempting indeed.
Maybe two phono stages with multiple inputs in each? That would be another point to mix it up. For example one solid-state and the other with tubes? With two cartridges that give you 4 possible sound signatures.My problem is that I am too curious and I need more inputs
My personal winner is the combination of EA-1200 plus T-2000 step up.
You are close to EA-2000 performance with the bonus, that 3x MC carts can be connected.
The phasemation 2000 was preferred to the CS port and Thrax phonos at Anamighty though they were very good too. Never got to try the 1200 with the phasemation SUT, I was interested in confirming exactly what you posted.
Anamighty had a very nice cable of their own that bettered the phasemation cable from the SUT to the phono.
It will be good to compare phasemation with properly rolled valves with Allnic 8000, EMT, Mayer, and a couple of the ones going direct from Eastern europe
