UPDATE ON RRV ie RIGHT ROOM VOLUME
Status
Not open for further replies.
If the OP is saying that one volume level fits all recordinds with minor (say + or - 2db) volume adjustments, I am speechless. Maybe I do not understand RRV.
And no OP, Steve does not need your help. To suggest otherwise is very pretentious and disrespectful.
And Steve, if you have detents (clicks) on your volume control knob, I totally agree. Volume knobs that have no such control, that is another story. What is the dB value of each click of your pre?
0.3 db IIRC
Here is just one example from two of my reference tracks which would appear to show the concept of RRV to fail:
Track 1: Artist: Willie Nelson, Album: To All the Girls, Track: Have You Ever Seen the Rain
Track 2: Beethoven, Piano Sonata #32, Anatol Ugorski. Deutsche Grammophon
These are both on Qobuz.
My notes show:
Willie Nelson: Spl 73 avg/85 peaks. Amp attenuator set to 14
Ugorski: Spl 73 avg/96 peaks. Amp attenuator set to 29
The amp used is .5 db per click, so that's a 7.5 db difference in how these two tracks match average Spl levels and more importantly sound right to me in my room. Setting either one of these tracks at the same volume level on the amp would be a sonic disaster!
Perhaps if you only listen to heavily compressed recordings, you might find one setting to work?
I trust the OP has received sufficient input from the "usual suspects". Maybe he has learned something.
Reactions: wil
I previously posted a volume numerical range on my pre from 35 to 65. Each value is 0.7db. And I typically listen to all music with peaks at 85db + / -. DUH!
As I sit here tonight listening to the stereo, I sort of wish his same volume for all songs was even semi-true, but unfortunately it’s totally false. I listen to my Lumin playlists on random shuffle, and I constantly have to turn the volume up for some songs, and down for others. That is how I get the same volume to my ears.
Reactions: Bobvin
I'm still interested in trying to understand anything. And since you opened the thread I assume you're interested in talking about it.
I'm glad you have recording experience, this should make the conversation easier. Let's try reducing the problem and try to squeeze out a clearer picture so we're not beating around the bush.
Your hypothesis is that there is one and only one adequate listening volume for a given room/set up. But you state this as 'once you find the spot in your volume control, it's done, don't move it ever again, no matter the source or program material'. Or at least you seem to from what I can see.
Allow me to put forward a small exercise. You record a given event. You make two masters from the same recording: one is simply 5db higher gain than the other, otherwise exactly the same. Disregard clipping, headroom, all the things that would tilt you towards an ideal gain in real life. So you have the same program, just with 5dB difference in gain. Your hypothesis is that you still should not move the reproduction gain/volume, the ideal setting will provide you with the best experience for both masters of this same recording?
Sorry for the reductio ad absurdum, but you seem pretty confident in your claims, so here shouldn't be a problem in digging deeper.
lol. I’ll bill you for the recording and mastering. That’ll be 5k. Sending my bank details…
Sadly youre doing it wrong and misunderstood the whole concept.
You appear to be trying to play tennis without a net, that's unfortunate.
Either because you genuinely don't understand what people are trying to say and deflect (incredibly bad I dare say) or you're just trolling, I'm not surprised you get this type of response from other forum members, but I'm surprised you get any response at all. Trying to give you the benefit of the doubt and attempting a conversation is futile and an exercise in moderate frustration.
Take care and don't forget to set your volume.
Extreme harshness is unpleasant whatever the volume.
Trolling. Hahahahaha. It’s you whos trolling coz you can’t stand that others join in on a reasonable discussion. Clearly you don’t know how to set RRV. Pity. ( and pity those who ‘like’ your sad response. )
My suggestions:
Witches Brew
Classic Records – LSC-2225
Crimson 20th Century Schizoid Man from In the Court of the Crimson King first press Island pink rim
The Beatles When I Saw Here Standing There from Please Please Me lp MONO first or third press
Miles Davis Blue in Green from Kind of blue Analogue Productions UHQR
Yes Fragile from The Yes Album Mobile Fidelity One Step
I’m using the app on my iPhone. Please post as you go. I’ll do mine later today if others care to join in. I’ll wait to see who’s game.
It really is astonishing... there is a claim that RRV is one particular value, clearly room dependent. But the fellow advocating for this isn't willing to share 1) his own value in terms of a db measurement along with some details about his room and/or 2) some method by which one goes about determining this RRV.
It would seem to me (but as I said before, I am just a layman) someone so devoted to telling the world about RRV he'd be willing to share his method/technique so we could all bask in the glory of RRV.
Otherwise, this thread is a repeat with no new information, i.e. worthless troll slobber.
Wrong. Go see the thread. I’ve posted my lp suggestions. Now join in or stop trolling … or don’t u have the cajones
Th
And I hope you share your room dimensions and the listening volume at which you listen at your listening seat? The volume must surely change depending on which recording you’re listening to, but I would like a rough idea.
why be so vague about your claims and not share more specific details about the method used to find this right room volume?
the volume NEVER changes. I thought I’d made that abundantly clear for RRV.
Respectfully when u set RRV u will not need to do that.
My suggestions:
Witches Brew
Can you add a string quartet, a choral recording, and a Symphony to your list?
Th
not the volume setting on your preamplifier, I’m saying when listening to a recording there is clearly soft and loud passages. Listen to a choral piece of music. Lots of change in volume level. Nothing to do with your fixed system output level.
Peter. Again, the preamp volume does not change. But yes, changes in dynamics are of course ‘a thing’ but the RRV adds to the magic in such scenarios, not subtract. I really don’t get what’s so difficult about this.
Hmm, how many predicted this thread was headed for a cliff before the train even left the station?
Do NOT put a locomotive on that track, its a waste of a good locomotive
I swear internet trolls are either part of a giant multimedia modern art exhibition, a psychological experiment to test our gullibility, or our alien friends checking out just how much of a push over we are.
Reactions: Bobvin
Status
