Full loom of Enklein "David" cables. Highly resolving, transparent, linear and very natural / organic sounding.
It was more a comment on the pointlessness of this thread, and that there is no correct answer. I think some people just like arguing.
But here is a question:
If you (not you in particular) set up a system in room with amplifier A and were happy with the sound and then you switched amp B, only to find that the mid and treble were superior but the bass was a bit off, would you give up and go back to amplifier a or would you experiment with other aspects of the setup.
Consider amps and speakers - they have a co-dependent relationship, with some pairings working really well together and others not so well and some combinations in-between. For each pairing there is likely an optimal setup within a given room. That setup may have a relatively broad or narrow range of position options.
What do you do when you bring an amp and pair of speakers into a room? You hopefully work out their best setup. Let's say you have a set of speakers to review or an amplifier to review. I would bring the review product into my audio room and proceed to setup the pair for the best positioning I could find. That's what an end-user would normally do. Do the same for the reference where one product stays the same (amp or speakers.) I don't think that is confusing or somehow deceptive to the reader if each pair has its own position. Just briefly explain what you've done and describe what you hear.
I thought he was referring to ddk’s cables. Guess not!Wow, they do come with some price tag:
Quite a difference with your previous Ching Cheng.
The thread is about how many variables are or should be in play for a review. "does changing more than one variable at a time change your opinion about the value of the review of the component being compared?" I will not write about what is correct, but simply describe what I do.
For amp A, which is my reference, I know where its speakers are positioned. If I bring in amp B for review, I try to find the best position for my speakers with that amp, starting with where my speakers are for amp A. If nothing sounds anomalous I'll stick with that, otherwise I will try for a better position. (Preferably I'd let the manufacturer set-up his product, but sometimes that cannot happen.) Beyond initial setup I would not experiment. At least I've not done that in previous reviews. I try to keep the number of variables to a minimum, but I'm not religious about it.
Yes, audio people do like arguing. If you expect to find correct answers in audio threads you may be disappointed half the the time. Someone will probably argue about that.![]()
What do you do when a new amp doesnt sound good in your system?
1 Call the dealer
2 Change cables untill it sounds good
3 Change the music untill it sound acceptable
4 reposition the speakers in the room untill they sound acceptable .
5 Open the door of the room and put the amps outside .
Hifi is simple just switch one component at the time , i would appreciate the same stance/ attitude of reviewers.
Why make things more complicated as they are already
I don't think that moving the speakers is something he does or for that matter anyone as part of a component trial but it can happen, sometimes a setup needs adjustment and the new gear shines a light on it. Frankly I'm surprised that people are so rigid when trying out new equipment I don't write reviews but I test gear or set up full unknown systems for myself and for people I simply don't see the big deal taking on multiple components including acoustics at a time. In fact I don't see a way around it.Hello tima
I have a question on this. Why would you change speaker positions?? I can take quite a while to finally dial in a pair between toe-in, listening distance and distance from room boundaries.
As soon as you change speaker positions you automatically change the in-room response. This is basic acoustics and well understood.
What you actually end up comparing is your speakers in different listening positions. No amp unless it's seriously flawed will have anywhere near the frequency deviations that moving speakers around a room does.
It completely gums up the works and if you have to change your speaker positions because of an amp change something isn't right.
Rob![]()
You don't work on the setup after first good impressions?For me its simple " expect no mercy " .
Good review / bad review , who cares ??
If i dont like it ......out bye bye .
Its the new component who should deliver the extra .
Not me having to do all kind of fiddling / adjustments to make it sound good /acceptable
If the quality aint there ,it aint there
No not really , i do reposition speakers once in a while , but thats more out of boredom / desire for a change in sound , perception .You don't work on the setup after first good impressions?
david
Mediocre and poor setups are a given but I often find excellent setups can improve with minor changes after introducing a better component. Speaker placement isn't only depth and imaging you can the overall balance of your sound by moving the speakers even an inch in any direction. In a big room with great acoustics this might not be a big change but in a small space with poor acoustics it's a given.David , arent you taking the worst cases into account
Like people who make a complete mess of system set up ?
I m just talking about what to do with adequate set up (systems)
I'm pretty much the same way testing new equipment including speakers. I drop it in anywhere to see if it's worth dealing with and go from there, first impressions matter! Of course it's different with other people's systems, I have to make it work as best as it can be and then give them a few suggestions and leave it at that.No not really , i do reposition speakers once in a while , but thats more out of boredom desire for a change in sound /perception .
A month later i d reposition them back for example .
Basically i have made my mind up about a component/ system in a minute( 5 min ) or so and this first impression rarely changes .
Amps or pre amps without good unit control , .... bye bye , i dont bother with repositioning .
Cables i never change
david
I m sure with clients it can be indeed a completely different story.I have to make it work as best as it can be and then give them a few suggestions and leave it at that.
I dont know of any cheaper tweaks.Audiophiles like to tinker. I get that.
In your case iirc the real improvement was the LAMM ( pre ) hybrid power amp.I used to experiment with my conventional cone speaker positions every now and then, but I eventually stopped when I realized I had exhausted my patience. I have two friends who continue to make small speaker adjustments regularly. Perhaps it is a result of new gear coming in, or they are still trying to optimize the positioning. Audiophiles like to tinker. I get that.
Which unfortunately you realised only when you sold the magico s
No speaker repositioning or cable swapping are gonna give you such improvements i think you ll agre on that
