Homemade Horns
Robh3606
1,480
468
1,155
Destiny
Hello sound of Tao
Looking forward to seeing this develop. With crossovers I personally prefer steeper slope as a first order is not at all as easy to do as it seems. I am talking about traditional caps and coils not DSP where you can time align the physical driver offsets.
You need to see what works best in your set up I ended up with 18db networks because I got the smoothest transition between my drivers so see what works , don't get hung up on a specific slopes. People can recommend whatever they want but with physical offsets each build is unique.
Have fun!
Rob :)
morricab
9,482
5,042
1,228
Switzerland
Hello sound of Tao
Have fun!
Rob :)
In my build I found 2nd order LR worked the best.
the sound of Tao
3,633
4,881
940
Hello sound of Tao
Have fun!
Rob :)
Thanks guys, the learning curve in all this is possibly even steeper than the crossover. Getting the crossover sorted for the radians is hopefully going to work in similar lines in approach with what I have already here for the 1.4 inch beymas that the new radians will replace. Likely I’ll go initially for similar crossover point and approach to the one that works with the current drivers as a start and go from there. Swapping horns from the bi-radial horn to the SEOS is adding another new variable but I’m lucky (given my little experience) to have the other driver horn combo at least here as a benchmark to reference against.
Robh3606
1,480
468
1,155
Destiny
So I have to ask how are things going?? Been a while! Have you made any changes and are you enjoying your DIY journey??
Rob :)
the sound of Tao
3,633
4,881
940
Hi Rob,
Many thanks for checking in. I’m probably slack, or end of year exhausted or a bit of both lol. Exploring horns and being more involved in design along with it has been the most satisfying move that I’ve made since starting up in the hobby. It feels like I’m more in the process than ever but I’m also enjoying the music and listening at the same time.
Even in their current iteration I’m very much loving the wholeness and vitality and their musically engaging nature and coherence so the idea that I have time and opportunity (and the parts) ahead to build further on what I have is a very good feeling.
I had underestimated how busy the last few months would be with my work but have set aside time in the New Year to be putting in the new Radian drivers and am also moving the setup into another room so unfortunately not much more to report till then. I also have to admit it’s summer here and ocean swims and coffee at the beach are currently getting kinda in the way of progress lol. Hope you are well and enjoying the season.
best wishes
Graham
bonzo75
22,619
13,637
2,710
London
Hi Rob,
best wishes
Graham
I thought putting more posters on ignore would have freed up time a bit
Reactions: the sound of Tao
Sandston
24
12
68
52
Very curious to hear your progress. I have the PAP trio coaxials and was toying with the idea of a Joseph Crowe biradial or SEOS horn with a coaxial compression driver from B&C or BMS or possibly the Celestion AXI.
