I don't like the Spectral better having lived with the PDS-5 for a few years now. Having said that the Spectral costs $5K more and only plays Redbook. Played in an all Spectral system it was very engaging. I like the PD MS-5 so much that I will be buying new outboard USB box for upsampling to 384 Khz Redbook and 6.1 Mhz DSD
And that's how fussy you have to be with digital -- it's worse than vinyl ...!!!
Frank
my only worry is that metronome is still using an old drive mechanism whereas esoteric ones are quite solid and becoming an industry wide standard
Agree with Orb...the Philips drive is excellent, time tested and well regarded among the pros with whom i've spoken.
One consideration and someone can correct me if I am wrong; the very best Esoteric drive mechanism is only used in their own reference transport, other manufacturers can only purchase the next one down in the tier (still not the entry one).
http://www.avsforum.com/avs-vb/showthread.php?p=17447742#post17447742a) Their top level transport used in the UX-1 and variants. This is a beast. The disc motor is buried in the 12 mm thick steel top bridge, driving the disc from above. OEM cost is $4000, with a minimum purchase of 50 units ($200,000 total). But it is no longer available as the laser has been discontinued. Esoteric is saving the few left for their own products.
b) Their second level transport is very similar and is just scaled back a hair. The disc motor is still in the top, but it is scaled back to 10 mm. Still a great transport. OEM price is $3000. There are only two companies that use this. dCS uses it in the transport of their $60,000 stack and Spectral uses it in their 4000 model CD-only player.
Good headsup RUR.
Cheers
Orb
I am on the verge of a decision wheter I should continue with transport+dac+clock or to switch to a one box cd player. Can I get your opinions on this.
My current digital configuration is Esoteric P-02+DCS Scarllati DAC+DCS Scarllati Clock.
Any comments on Burmester069, Soulution 5 and 7 series cd players, Metronome Kalista or any other digital single boxes vs separetes of Esoteric or DCS or MSB or EMM Labs?
Sam, thanxs for the comments, i will be testing as well Playback design and also MSB (dac only not transport). by the way which cables are using btwn transport and dac?
Emre
Basically I have 2 reasons one is the itching factorthe other is the advancements of mechanisms structure and mateials giving more silent and error free reading.
