Speakers up to $30K
iaxel
545
335
298
Yet another “recommendation/suggestion” thread...
Playing with the thought of replacing my speakers (Magico S3 mk1).
Currently driving them with a Luxman m900u connected to a VAC Reference preamp.
I listen mostly to classical music, some classic rock/prog-rock and jazz.
Current considered candidates are:
Magico S3 mk2
Rockport Atria 2
Vimberg Mino D (diamond)/Tonda
Looking to stay in the “wanna-be-colorless” camp. But am open to interesting suggestions/directions.
Thanks!
If I were in your shoes, those would be on my list too, along with the Wilson Yvette and Revel Salon 2. After hearing the S3 Mk1 late in its cycle, I decided to wait on the S3 Mk2. I'd do it again. Great fit for my room and tastes (mostly classical/jazz).
iaxel What is your room size?
Approx 24x12 feet, but the speakers are located on the long wall due to some room restrictions. So I sit pretty close to them (~8-8.5 feet).
I have a pair of M900u's driving YG Hailey 1.2's in a 14x19 foot room (I sit about 9' away), and classical and jazz sound great. Frankly, in a room this size I can get away with just one M900u in stereo mode, but since I have both ...
If you're in the US, demo stock of the original Haileys can be found for less than 30k. I've thought about upgrading to the newer Haileys, which are by all accounts superior, but frankly I'm so happy with the 1.2's it's not worth the bother of crating them up.
Happy hunting.
Parker
Thanks! Did you decide to wait on the mk2 because you knew they were coming out or because you’ve felt something was missing from the mk1’s?
And regarding the Wilsons. I’ve heard the Sophie 3, which the Yvettes are aimed to replace, and IMHO they were nowhere near the S3s.
I
I decided to wait because I felt the original S3 bass was a bit light (although wonderfully well defined) and the treble felt a bit tipped up. The Mk2 addressed both concerns.
Amongst the speakers in your OP, I like the Magico S3 Mk2's and Vimberg Mino D. I think the Tonda would be too big for your room. Here are some further suggestions..
Up to $16kUS, I like the following speakers...
- Devore Fidelity GIbbon X @$15.9k
- Joseph Audio Perspective2 Graphene @$15k
- Audio Solutions Figaro L @$10k
$16k - $30k, I like these speakers...
- Magico S3 Mk2 (as discussed)
- Vimberg Mino D (as discussed)
- Wilson Benesch ACT One Evolution @circa $30k
- YG Acoustics Vantage @$32.8k
As always, trust your ears. At this level, an audition is strongly recommend if you can swing it. Good luck with your search!
I
Thanks!
Happy hunting.
Parker
Sounds interesting, unfortunately, there’s no YG distribution where I live.
Revel Ultima Salon2
Magnepan MG-20 or MG-30
Sanders ESL
Thanks!
There’s no Revel and Sanders distribution where I live.
Regarding, ribbons, I believe they require much more space to “breath”.
Thanks Bodhi!
Do you think the Devore X is a worthy contender against the S3?
I’ve auditioned the WB ACT one in the past. They are lovely speakers, but, to my taste, a bit lacking in resolution, scale and bottom end.
Thanks Bodhi!
Yes the Gibbon X is certainly worthy of consideration. That model, along with the 0-93 & 0-96 offer great bang for the buck. The Gibbon X however is more of a full range speaker. Re: the Act One, fyi the ACT One Evo is quite a bit better than its predecessor in the areas you mentioned, so maybe worth revisiting.
Thanks!
Where do you live? A $30k investment may be a worth a little road trip.
If by "colorless" you mean "neutral with accurate frequency response" then Revels are a great choice IME/IMO. Read some of the reviews and comments here, at AVS and other fora, Serophile, etc.
Sanders is mostly direct sales these days AFAIK.
The Magnepan MG-20 and MG-30 (and MG-3) include a ribbon tweeter but the rest of the panels are technically planar-dynamic and not true ribbon speakers. That said, any dipole (ESL, planar-dynamic, ribbon, or using conventional drivers) either needs enough space behind to reduce comb filter effects or a well-treated wall behind. I did not think your original post mentioned room size or speaker positioning, sorry if I missed that. *Edit: Saw your later post. If you can pull the speakers 3'-5' from the wall behind they should be OK.
If you are not familiar with planar dipoles you should definitely listen before purchase. People tend to really like them or dislike them, not much middle ground IME.
I have not heard most of the other speakers and just threw out some alternatives based upon my experience. Speakers tend to be a pretty personal decision and there a lot of great ones these days. Makes choosing harder in a lot of ways...
Reactions: davidmiller30
Interesting, thanks!
I have home demo’d the Devore O93 and it didn’t really “click” in my set-up. Could be positioning or amplification...
Regarding the WB, I believe it was the One Evo, as it was no more than 2 years ago.
IMO, the Sophia 3s are a much better than the Magico S3s.
What amps did you try? Don't you have a Luxman?
The Devore 0rangutans have good synergy with tube amps such as Audio Note and Leben. The Gibbon X, whilst happy with tubed amplication, are best paired with a ss class A amp imho. The classic Coda Model 11 comes to mind.
Reactions: bonzo75
Yep, with the Luxman. Not sure what was wrong (or not), but the O93 did not impress me at all.
