78!
david
Stored energy increases with the square of the rotational speed - is the AS2000 certified to be safe at such high energy?
I imagine that stopping the platter by hand can release a lot of heat in your fingers!
78!
david
You have inspired me Tango !@ddk. You should get this album to show how natural nuances can come from your tt. In fact every one should have this album. The performance is great and the sound is awesome.
@audioquattr. I cant help not teasing you man. You havent heard your Zeta until you hear them with the Lamm.
Kind regards,
Tang
More Piano Music
Just admiring her foot work, I am sure she can drive a stick shift, not just an automatic like most girlsI hope this vid is for those legs and nothing else![]()
What I like to say is in reality, some tts are just "better" than the others. There are cases where saying "sound best upon preference" just cannot really apply because some tts are just "better." It is not about preference.
OMG this thread is priceless!
David, PLEASE name your next table the Double Entendre
I have been listening to the AS2000 close to a year now. A friend in wbf pm'ed me asking what I think of this tt in comparison to my AF1P. The following is what I wrote to him. I hope he does not mind I put this on public. My comment is only based on the sound of what I hear in my system. In other system it could be different. My good friend and also my audio mentor, Gian, always tells me in audio even if your are so sure, you cannot be so sure. Too many variables when we talk audio. Hearing preferences are also diverse. Apologize for my bad English.
"It depends on how you would like to listen to music. The AF1P organizes sound for you. It sounds very very nice and exciting. Most of the time more exciting than the AS. Stage is always wider. Instruments are nicely laid out or spread out. AS could sound more like instruments stand closer together. It even sounds more evenly dynamic than the AS2000. More immersive too. Heavier stronger bass too. These are characters or footprints of AF1P.
The AS2000 does not seem to have pattern of characters. Its character is a no-character character. You will hear different records more differently. You play one record you think AS2000 has no bass. But then you play another record all of a sudden you get this bass slam. You listen for a while you will realize the bass comes from the recording itself...as how it was in the record...differently. The same thing I described applies to sound stage, dynamic, etc. At beginning I thought the AS sound stage is inferior. Then I played another record and I was wow by how wide and immersive the sound came out. If two different records are remastered by the same process you will hear that pattern of sound on the two records quite easily too. Music seems more real and musical because the AS exhibits more contrast. The transparency of this tt is phenomenal. You will hear more. It is the nuance king. This tt changed my way of hearing reproduced music. It seems to have changed Christian too."
I prefer not writing any particular aspect in specific because at this level of tt they stand head and shoulder aligned. For example, People like to say how quiet a tt is. I think quiet is easy to make since I finds all tts I own so damn quiet. Kronos can play extremely quiet. Vinyl itself determines quietness imo. So difference of tts in my view is on characters. You cant get the characters of each tt it means you havent understood it.
On practical side of things. The AS2000 is very bullet proof. I find it as reliable as the 927. I only had one incident with it when the lube under the platter splashed because I put too much in at the first place. Everything is easy fix even a lazy person like me can do it...well with a few strong guys help lifting. I say this and David hear it would go crazy at me. When I couldnt get some lp's through the spindle I actually used my fist banged on the vinyl to flat out on the platter. The AS can take the beating..hehe. The setup is also the easiest and most simple of any tts I found. Easy set and forget. I did not need David to do it for me. He came to teach me how to set up the cart and 3012r so that I could hear the AS at its full potential.
Kindest regards,
Tang
IMO the most natural and realistic musical experiences are from equipment with little or no obvious footprint as I'm sure you've experienced even more since you got your Lamms!
Thanks Tang for your one year update. Have you played the SME 3012R and the Opus or VdH on both tables? I'm trying to get a sense of whether or not the sound characteristics you describe are attributable to the table only or rather to some combination of table/arm/cartridge.
Also, you describe the AF1P as having a super wide soundstage. Are there any instances where the same recording has a wider soundstage on the AS2000? It seems as though there are more distinctions between various recordings when played on the AS2000 than there when played on the AF1P. That would imply to me that the AS2000 is a more transparent component contributing less to the overall sound, as long as this is based on the same cartridge/arm/phono being used.
I did not quite understand your question Folsom so I was afraid to reply.So no comment on timbre between music and the vinyl noise AF1 vs AS2000?
