No not yet. I was in car for 6 hours yeaterday so I practiced knotting to kill time. Will try fishing string today. Gosh. We are nuts. Next thing we try probably be what type of lube we should useTang/Christian,
No string drive yet with your AS TTs? Think you are in for a good surprise.
Best.
No lube Tango, bareback again, you need friction.No not yet. I was in car for 6 hours yeaterday so I practiced knotting to kill time. Will try fishing string today. Gosh. We are nuts. Next thing we try probably be what type of lube we should use
Kind regards,
Tang
I knew it! I was gonna edit and said "Btw, Lagonda, dont you be thinking kinky bareback again."No lube Tango, bareback again, you need friction.
Don’t worry the RON system is using its capacity calculating giant subwooferI knew it! I was gonna edit and said "Btw, Lagonda, dont you be thinking kinky bareback again."
Have you noticed I didnt make no comment with the joke when you guys were at it. I am on most wanted list man.
Tang
Kind regards,
Tang
Where you watching the instructional video you sent me when you did yourKhun Tang,
Who do you think did the research on that magic bottle of lube you got with your tt?
david
Dr. Lube!Where you watching the instructional video you sent me when you did your
“research “ ? Target angle for VTA is 91 degrees ?
Wow 78 rpm on a high displacement model like the AS is quite a feat !78 !
david
I thought only the smaller Asian models (micro p.) could perform at that speed. Hope nothing breaks, it could be carnage
I think the spelling is Asiamuff in this case ! When the groove is really wornJust don’t forget to align your Azimuff
So true Marc, so true ! Austin Powers is sophisticated compared to our sillinessPeter, this is more Austin Powers than it is James Bond.
