Update- I have sent my whole DAC with renderer in for a check-up with MSB. Let you know what they find. It could be the DAC or the Network Renderer v2 module. The folks at MSB are really great to deal with.
Anything to report on this?
A question for the MSB experts - the MSB renderer supports 100Base or 1000Base connections?
It is 10/100Base.
To put things in perspective, that's 1MB/sec, and a hi-res file would require 192Kbps, which means 5x the headroom, at 10Base. 100Mbase, 50x the headroom.
I don't think it's a mistake, as Gigabit receiver chips might as well be noisier, and simply not required for the purpose.
Besides, if Gigabit becomes absolutely necessary, it's just a module change away. Try that with other DACs, which, AFAIK, are mostly always 10/100Base as well.
Now, where Gigabit IS necessary is at the NAS/server level, as that one unit might be serving multiple devices. So, 5 streams at 192Kbps from one server might become problematic on 10Base.
You are missing my point which is compatibility. You would hope MSB could figure out the noise........
Compatibility with what? Care to explain?
As someone who is averse to computer audio, but is feeling more and more compelled to have to dip my toe in the water, do you pro streaming guys realise how offputting these discussions are?
It would mean you cannot bridge the network connection to a 1000Base network adapter as some like to do to "isolate" the renderer from the network. You will also need a switch supporting mixing 100Base and 1000Base connections, a lot of switches will switch all ports down to 100Base when there is a 100Base device connected. And indeed you would need a 100Base supporting FMC (not very common but available) if you want to use fibre networking. But like you said, 100Base is fast enough for virtually all formats, as stereo 32/768 PCM and DSD512 top out at around 50Mbps!
You’re saying you use it as a digital input or is it your network Bridge?A little bit off topic but, I like the SQ of the Renderer V2 a lot. Maybe it´s not as pin point as the one I get from the MSB Pro USB but it´s warmer and more life like, if I can make myself understand.
Also, I love HQPlayer. I don´t need Roon or other players highly resource consuming in the streamer. I think the Renderer V2 would benefit if their firmware/software could include the NAA code. The implementation would be something like - Streamer » Network Bridge enabled to avoid switches » MSB Renderer V2 with NAA enabled » DAC. This implementation simulates the 2 machines version, without the cost of the second one.
Just a guess, but I beleive if MSB wanted to do this step it would be a forward one.
