Tim-They are supposed to release a vinyl set cut from the digital masters.
To me, this seems silly. If there are to be releases of "digital masters", why not release them in that format (whatever it is)?
They've already been released digitally.
Tim
This thread has diverted as usual. The original poster's question should be fairly easy to calculate from first principles. The diamond that tracks a vinyl groove has finite dimensions. The most advanced such stones have two radii of curvature, one along their axis and one across it. The latter radius, which is the smaller in elliptical or more sophisticated profiles, is the one that does the information retrieval. Any lateral information that is smaller than this radius is hardly going to be noticed by it and, if a lot smaller, will be completely missed, just like a car with large tyres will not be disturbed by a tiny pothole. Based on any particular diamond's profile (for example the Ortofon Replicant stylus has a contact surface of 5 microns minimum radius), the distortion the cartridge creates when tracking a groove of similar displacement, the voltage generated, and factoring in subsequent RIAA deemphasis, at least the bit depth required should be relatively straightforward to calculate (for similar harmonic distortion levels). The frequency response necessary can also be approached along the same lines.
It may be simple for you, but definitely not for me. So do you feel like crunching the numbers since you know how? I would personally appreciate your efforts as I believe others here would.![]()
The vinyl issue interests me little, therefore I'd rather delegate scutwork. I'm sure there are mathematically inclined volunteers to do it. If not, so much the worse for themdo you feel like crunching the numbers
They were recorded and mastered at high definition and you listen to them at the Red Book level. This accounts for the objective deficiencies. If the vinyl interface adds its own euphonic ingredients and you like them, it is a matter of personal taste and therefore of no interest to those who do not share that particular taste. If you prefer vinyl material mastered from high definition masters, try to audition it in its original form and decoded by the same equipment used in the mastering process. Only then will confounding variables be eliminated.I enjoy records more than digitally sourced material, mostly. But I know they were digital during mastering. It doesn't make sense to me
I guess I mistook your participation in this thread for interest. My bad.
(...) If the vinyl interface adds its own euphonic ingredients and you like them, it is a matter of personal taste and therefore of no interest to those who do not share that particular taste. If you prefer vinyl material mastered from high definition masters, try to audition it in its original form and decoded by the same equipment used in the mastering process. Only then will confounding variables be eliminated.
Exactly so!Since so many people love the sound of LP, I see nothing but opportunity in cloning that effect in digital domain.
Since all sorts of equipment used in studios is freely available, the only case for what you describe to occur would be that certain studios use custom-made equipment to their own exacting specs. AFAIK some studios do, but most do not.BTW, one plausible theory that was put forth before was that a digital master converted to analog in the studio in the process of getting converted to LP may have an advantage in doing the same in your home
Since so many people love the sound of LP, I see nothing but opportunity in cloning that effect in digital domain. So who has characterized that coloration and can supply us a digital file with or without so that folks can listen and tell us if they are hearing the LP sound in digital? After all, if the theory of coloration is right, then that transformation by definition can be applied to a digital stream.
