I also have arranged to purchase a second Studer A820.
May I ask why two Studers?
Kind regards,
Tang
Ron,
congrats on these significant decisions. I know these were big things on your mind and hopefully you can get some peace of mind from having these parts settled.
I applaud the 2nd Studer A-820, the VTL Siegfried II's, the Taiko Tana, and Io Eclipse. great products all.
those VTL's should eliminate any concern for power with your Pendragon's.
cheers,
Mike
Move-in day must be getting close, congrats Ron!
david
Nice choices across the board. Glad to hear VTL will be your amplifier. I think it’s the best choice to match with the Aesthetix preamps’s.
Awesome Ron. I see no weakness. The kind of system that only comes from extreme knowledge and methodical due diligence.
Great amplifiers. There is a pair playing beautifully less than 2 miles from me! When do you expect to to move the complete system to your room?
Kind regards,
Tang
Ron,
unless you have many, many tapes...you will get board with the same music over and over. That's where vinyl kicks in.....so much more variety and not far from tape sonically.
Sorry to hear it’s still so far awaySadly, David, no. We are now thinking we will not be in the house until October or November.
The VTL series II has been upgraded to a fully balanced topology. The input impedence is complimentary to your long cable run from the preamp. You can switch between the various modes and feedback to tailor the sound to your liking. Enjoy. At this price I would consider the Boulder 2160 but I understand you are a tube man all the way.Thank you, Dan. I personally have found Aesthetix and VTL to work well together.
Why do you feel the VTL amps are a good match with the Aesthetix pieces?
Tang, I hope to get deeper into the tape club (cult?) In general, I just think tape sounds amazing. And no VTA to adjust per LP (haha Peter!
) Also I have learned the potential value of being able to dub from one machine to another.
At Mike's I saw again the amazingly gentle way the A820 handles tape. That is reassuring for tapes that cost $450 per reel and up!
I have ordered a lot of tapes from Leslie Brooks over the last couple of years. I also ordered three of Chad's tapes, and I am sure I will order more as his library grows. I hope to get deeper into the master tape sourcing world (underworld?).
Finally, once the system is set up I really expect that more than a third of my listening will be to tape. I would not be surprised if, over time, I listen 60% to LP and 40% to tape, or maybe even half and half.
Since my musical knowledge and interests are pretty limited (I have maybe 10 favorite classical pieces and maybe 10 favorite jazz pieces) I already have a fair fraction of my favorite classical and jazz music on tape. I even have some of my favorite 1970s and 1980s rock and pop stuff on tape already.
Mike has taught me the sonic value of 45 rpm. As Classic Records did 33 rpm reissues and then 33 rpm reissues on special vinyl and then 45 rpm reissues, and then single-sided 45 rpm reissues, I bought every iteration each step of the way. I will want to sell all of the earlier variants and keep only the 45 rpm versions of albums of which I have multiple iterations.
Ron
What was the problem with the hillside that started the rebuild process?
Two weeks after I set up my long-term system in the space you see in all of the photos the painter came by to do some touch up work and noticed that the sheetrock on the concrete retaining wall on the inside (the front wall of the listening space) was wet. This location is, on the lower floor, about 20’ below street level.
A lot of forensic water testing indicated that the concrete retaining wall holding back the hillside under the street above from demolishing the house was improperly waterproofed. So the entire retaining wall –– 120 feet long and 22’ below street level -- had to be excavated and re-waterproofed.
It was like they were building a coal mine deep under the street. That phase of the project started five years ago.
You have an amazing tape set-up. You have A820 + Doshi tape preamp. Many people consider that to be the best set-up these days.
Mike played for me on tape some very convincing jazz.
