Well this is one reason why I created this forum to help bridge the gap between Pro and Audiophile. I've been on the front lines of this dilema for a decade. I always ask people, do you want good sound or a plug-n-play user interface. You're not going to get both. Not at this time anyway.
Good sound, like many of you know, you have to work for it.
The most stable and best sounding configuration I know of is Lynx AES16 or RME AES32 into an outboard DAC that accepts AES/EBU. When you start mixing USB, Firewire and other non-standard connections, you'll run into problems. On the MAC side it's easier. Going firewire to a Metric Halo is the best on that side.
Someone stated above that I like S/PDIF... no I don't. I like SDIF-3. It's a different protocol that is carried over a 75ohm coax as well, but can only carry one channel of PCM or DSD. You will find these connections on the back of a Tascam DV-RA1000HD.
I feel USB DACs were made for people that are more familiar with computers and were trying to make an easy situation. Most of the time they work great. It's even worse when you start going from USB to S/PDIF or mixing conversions. I would stay far away from that situation unless you're a total geek and/or don't have a life.
I'm not sure I agree with the above for non-studio use. There are several examples of very high quality DACs, and even some ADCs, that are USB plug and play and deliver excellent 2 channel performance without even any special drivers required. I'll put the performance of some of these devices up against anything for 2 channel playback. If anyone wants some examples, please just ask?
Thanks for the reply. I'm still poking around here getting my feet wet and trying to understanding the goals here. Obviously there are many kinds of "best". If this website is about Robb Report levels of excess, then yeah, I agree with you. The mission says:I totally agree with you that there are several USB DACs and ADCs.. the Lavrys and Benchmarks come to mind. They do a very commendable job but I don't think they represent the crux of this forum.... "What's Best". For the utmost in recording and playback with no compromises, I'll stick with my suggestions.
And a good thing too as otherwise, there would be no reason to have a forum!The mission says:
"The best doesn’t mean the most expensive. It simply means that it stands head and shoulders above everything else in its category."
That helps but it's rarely so black and white. Such a single stand-alone product in the audio business is rare. And when you try to balance price, measured performance, sound quality, build quality, appearance, etc. things become even more fuzzy. The best built product might not have the best performance for example. And the best performing product could be some piece of pro gear that might be out of place in a high-end home system.
Exactly. What we try to do is to have the discussion be peaceful so that different points of views can get out without tension.So I'll poke around more, but to me, it usually comes down to discussing the relative strengths/weaknesses of a given genre of products and others can decide from there what matters most to them.
I'm not clear how you fed the Behringer before you tried the AES16? Did you use a TOSLINK output from the RME soundcard?RME HDSP 9632 connected 2 ways (RCA & Toslink) to
TC Electronics BMC-2 as DAC+volume control.
XLR cables to
ADAM A7x active monitors.
Recently I had purchased a Lynx AES16 soundcard (XLR dig I/O) . Unfortunately BMC-2 doesn't have any XLR dig input, only RCA & Toslink. I guess I could use a kind of adapter to go from the Lynx AES/EBU connector to the BMC RCA input but I didn´t like the idea of losing the balanced mode in that digital stage. In fact I bought that card to try that (the RME has that option, but I couldn´t get the proper breakout cables available easily).
I tried the Ultramatch, as a pure DAC and upsampler, between the RME soundcard and the ADAM A7x (each one has a pot to control the volume). Psssh, different sound, but not better.
I tried also the Ultramatch as a pure simple sample rate converter between the RME soundcard and the BMC-2. Same results: different sound but nothing that I could really call "Better".
Finally, I decided to take the chance of the Behringer's XLR dig input, to install the Lynx AES16 and send the Lynx AES16 dig. output to the Behringer, upsample the data up to 96 kHz and, still in the digital domain, send it (through both Toslink and RCA) to the BMC-2 (DAC + volume control).
Where, and how, the clocking is done can certainly make a difference. It's no secret the AES digital interface has some advantages. But, I can make a pretty strong case, it has no audible advantages for PC audio over a properly implemented direct USB connection to a single "box" for 2 channel playback.
If you already have an outboard DAC/Interface you like that supports AES but not USB or Firewire, then an AES16 might make sense. It also makes sense for 24/192 or multi-channel recording. But for everyone else reading this thread interested in 2 channel playback, I'm less convinced.
The AES16 by itself costs more than many very high quality, and well regarded, stand alone USB DACs. I'm not sure it offers any real-world advantages over some of the best USB devices for stereo playback. A USB DAC also doesn't require opening your PC up, needing the right kind of free slot, and they're much more portable between computers, work on laptops, etc.
So, IMHO, the AES16 is at a disadvantage compared to USB in several areas. And if doesn't offer an audible advantage playing back commercially available 2 channel formats, that makes it a less than ideal choice for someone looking for a high quality computer audio solution--even if cost is no object.
If you don't need level controls or multiple inputs, I'd strongly suggest looking at the HRT Streamer DACs:Of course, if you know about a (not expensive) DAC which connected to a PC through USB can beat a Lynx AES16 + Lavry (or Benchmark) DAC, I will be delighted to know ! I don´t want the most expensive system (at all!) but the maximum quality at the lowest price... as any smart person, ...I guess (wrongly, I presume).
I haven't yet done a direct comparison--objective or subjective--of the Benchmark vs a HRT. If you're in the EU you might consider the higher-end Firestone products if you haven't already. The Libby is their flagship:However, I can see that you like Benchmark... Any opinion regarding the suggested HRT vs Benchmark ?
I agree! It seems 'async' has been latched onto by several companies as their latest marketing spin and product differentiation strategy. HRT is in that camp as well.Just a personal preference: if you go for a USB implementation, go for one at least USB audio class 1 compliant so 24/96
Probably asynchronous USB is to be the preferred mode.
NwAvGuy,
Would love to see you measuring the difference between a adaptive mode e.g. Benchmark DAC 1 USB and a asynchronous one like Arcam rDac
I see the new TAS has a soundcard round-up that Carl Schuster is reviewing. The contenders are: Lynx AES16/L22, RME Hammerfall HDSP-9632, ESI Juli@ and Maya44 and Echo Mia/Gina
I cheated and read which one he preferred! Shocker!
I couldn´t read that review although... I already know which is the "one".
Bruce, do you know what DAC they used for the test ? Thanks !
He's using the Bryston BDA-1
Pretty good review, even if I don't agree 100%
Bruce,
What would be your advise for a reasonable price PC soundcard to be used with the RCA SPDIF input of Krell S350a CD player?
I have been burning-in this player for the last month, and it is an excellent sounding CD player with a digital SPDIF input, but limited to 96 kHz.
I'd certainly look into the ESI Juli@ and the Avid/M-Audio Audiophile 192
