No, I never got the S7's. I was actually just attempting to get a rise out of forum member ack (of course it didn't work).
We should play poker. Only way to get your M-Pros.
Always wanted to listen to a quality SS pre into a quality valve power. Normally get to hear the other way round. It would be good if you can audition the CAT pre and see the difference.
What differences have you found in vocals, tones of violin and woodwinds, brass, and general orchestral?
Many thanks for the update. What is recovery of low level info such as hall ambience like with the JL7s? Are you using any support under the amps and what power cable are using? Look forward to further updates especially if you get to try a different preamp such as the Legend.
Ian, if you do change your preamp to a CAT, I think you will then see why I am such a big fan of Ken's gear.![]()
In general there is more 'meat on the bones' and instruments sound fuller and more immediate. Violin leans a bit more towards wood than steel. Brass is less brassy than the Pass (if that makes any sense) but is less compressed sounding and more rounded.
I've been playing RCA Living Stereo Shostakovich 's Age of Gold Ballet Suite and it sounds incredible. Great separation of instruments, beautiful timbre.
As for using a solid state pre into tube amps, basically I'm mimicking people who go straight from a digital source (e.g. Berkeley Alpha DAC) into tube amps. It works.
If your going direct from your Dac to the Cat's how are you playing your vinyl ?
Cheers,
The JL7's have a richer midbass & midrange than the Pass which is more extended (as you might expect between tubes and solid state). Yes, I have the KT-150's which I love. Both amplifiers have their virtues. The Pass can sound a little more mechanical and steely in the upper midrange (the latter can benefit some instruments). I think the Pass is also more detailed (or at least one can perceive it that way due to more high frequency energy) and has a wider soundstage.
I'm not sure how to answer the question about hall ambience - I'll have to think about that.
As for the amp support - funny story: I had a pair of HRS amp stands that I used to have under my Doshi amps. I pulled them out to use under the JL7's. I got very little bass and the highs were VERY forward. I then got advice to not use any stand with any form of mechanical isolation (which seemed to describe the HRS) so I removed the stands and the amps changed dramatically - bass appeared and the edgy highs disappeared. The JL7's have interesting flexible (rubber?) legs that provide all the isolation it needs.
Most isolation techniques, footers, etc have an adverse effect on bass, and some parts seem lost. Haven't tried on HRS stands but does not surprise me.
Has Peter heard your system with the CAT amps?
Thank you, Al. (You, like I, use tube amps so I am not surprised you mostly agree with Ian's assessment. I am sure I would agree too.)
You're welcome, Ron. I actually thought that Pass amps have strengths similar to tube amps *). In some real sense they do, but hearing the gear side by side reveals the differences.
____________
*) Spectral falls in that category too, in my view
