Do you happen to have an English version of the review? What other amps did they compare it to? I have owned the JL2 for many years so am also interested in the latest developments including the Amorphous core. Many thanks
Anyone know what the amorphous core is all about?
Usually it means low loss, but they have other problems... best to ask CAT about this. Changing amps again????
Need something to drive my new speakers.
sorry to hear the M-Pros aren't doing it for you, MadFloyd - hope you can find a speaker that really suits you.
as far as CAT, working with that company requires patience. and you should be warned his amps can heat a small barracks![]()
Hello MadFloyd. I see that you are using the CAT JL7S! Congratulations! How is the sound compared to the Pass XS-150? Are you using the KT-150 tube?I never said anything about my M-Pros not doing it for me. I hug them at least once a week and at 400lbs each, they provide me with lots of exercise.![]()
Hi so did you get the S7s? What pre do you use with the CATs?
No, I never got the S7's. I was actually just attempting to get a rise out of forum member ack (of course it didn't work). I wasn't starting a second system and I'm totally satisfied with my M-Pro's.
I'm currently using the Pass XS pre with my CATs. That may change.![]()
The JL7's have a richer midbass & midrange than the Pass which is more extended (as you might expect between tubes and solid state). Yes, I have the KT-150's which I love. Both amplifiers have their virtues. The Pass can sound a little more mechanical and steely in the upper midrange (the latter can benefit some instruments). I think the Pass is also more detailed (or at least one can perceive it that way due to more high frequency energy) and has a wider soundstage.
