I like it big . Probably 1 of the biggest if not heaviest Dac in town. Having seen what is inside the main unit & psu , its definitely a very well built DAC with the king size capacitors & transformers
Joshua, FWIW I loved the sound of your DAC when I was in your room. The sound was indeed wonderful but as I told you the overwhelming size of the unit would preclude me from ever owning it as it just occupies too much geography for my room.
With those prices you reel off, the Lampi GG is positively a bargain!
SE GG is about $15K retail and is 2 Dacs in a single box, PCM and DSD4x.
No doubt the Cassandra sounds great, just look at the components and I have no trouble believing that, however, even the basic one is nearly $40K no?
I heard the MSB Select at a show and the Chord Dave impressed me as much if not more.
14k euro for single ended. 18k for Bal and i think VAT is jn that...but not sure. I am in CH...so outside the EU and we use CHF here.I meant to compare it with Arie Cerat reference Dac. I heard Lampi GG it's good as well . Selling for only USD15k ? Fr 6 moons , I understand it's retailing for €18k , abt the price range of AC reference in Europe
From memory Stavros uses some big iron in his output section...so it in the vien of the Lampi design...overspecced power section too. See earlier posts in this thread.Hi Norman,
What are the boutique parts in the Kassandra, I can't see much from photos?
Euro prices are on the website lampizator.eu
I think you need to use the configurator to specc out a test order to get the exact euro price. I guess dealer prices may vary a bit.
Interesting that this all-out-assault on digital is from a designer who uses AN1865 chips (which Audio Note's DAC 5th Element also uses), and who also according to the article "opines that there is nothing wrong with the Red Book specs and 16-bit 44.1kHz can capture everything in music even though the Kassandra 2 DAC can handle PCM files up to 384kHz."
i also enjoyed reading that "The AD1865 is a Non-Oversampling chip which many have compared favourably with the legendary Philips TDA 1541 chip."...seeing as how i am listening to a TDA1541 double crown right now!![]()
I had a tube Dac with the AD1865 in the past. It was very good, but of course could not hold a candle to my R2R Golden I presently own. Implementation does matter, but i find the over focus on the digital part strange when its clear the Kassandra and Lampi have HUGELY overspecced analog output stages (and power supplies), in short - BIG IRON. That is where most of the magic may indeed resides...
Yes Lloyd, A pal with Gen 3 L4 in Boson also has a Zanden and described many of the features you set out for it. I think AudioCrack also had Zanden Transport and Dac too.Good to know, and i could believe it and would love to hear this particular DAC. With my own experiences, i feel that, for its time, Zanden digital showed great attention to many details which people still focus on today in digital (shielding everywhere), focus on power supplies, separate power supply boxes (2), and actually internally 6 different power supplies for different functions (6 in the case of the Zanden between its DAC and Transport), good (constrained layer?) acrylic isolation for the transport, etc.
I have found through experimenting that continuing to focus on isolation (HRS/Stillpoints on top and bottom), plus shielding all the umbilical cables (Entreq wraps) has continued to show improvements. And changing out all the power tubes to Mullards from Brent Jessee and the signal to an Amperex 7308...the change in the power tubes was frankly one of the biggest and best surprises in the improvement. So coming back to your point...i could easily see something of such seemingly small draw benefiting from a great power supply.
As good as the small signal tubes were, I find the DHTs shine at a significantly higher level.
