Sorry, Peter, you just said "mini monitors," and a reference to recording in that post caused me to jump to the conclusion that you were talking about recording monitors. I don't know the Magicos, but I imagine they're excellent with appropriate amplification. And FWIW, I don't think most studio monitors have that over-bright characteristic that they always get dismissed for. That typically occurs in semi-pro/hobby recordist monitors that are much less expensive than good pro monitors. My "monitors" are made for home use, with silk dome tweeters and active amplification and crossovers crossed low enough to prevent the 6" mid-bass drivers from trying to reproduce frequencies they can't handle well. They are pretty smooth and clean in the upper registers. This combination of amplification/crossover technology and driver size is pretty close to ideal, IMO, but really good passive monitors also do very well with the right amplification, it's just significantly more expensive to get them there.
Tim
Tim, I think we are both confused, actually. I had forgotten that my OP mentions Al M's system in which we heard the digital recording of "Tom's Diner". Then I briefly mention listening to my system in the rest of the post. If you are interested, you can look up either or both of our systems in the Member Gallery section. Al's and my mini monitors are quite different in design and execution and make for an interesting comparison. They both sound good and have appropriate and excellent amplification. Beyond that, the systems are quite different. Digital vs. Analog, Tube vs. SS, Subwoofer vs. none. Mostly vintage vs. current gear. It shows there there are many paths to good sound.
