The appeal of Martin Logan belies the objective measurements of it. Here is a random example:
Clearly above 2 Khz, performance goes to hell. There is nothing remotely high fidelity about a loudspeaker that goes nuts that way. When I listened to them blind, I thought the speaker was a broken one put in there as a control to catch deaf people. Whereas prior to that, I thought they were a very good speaker. Now sighted I can hear the same issues and no longer like their sound.
It is very, very, very difficult to measure a dipole loudspeaker and correlate that with the sound you get if you don't measure it correctly. I don't know how this was measured, but if there was some surface in proximity - it could be anything: a wall, a desktop, etc. - you might get some comb filtering from reflections of the rear wave depending on the gate period. Now sighted, you might be hearing your expectation bias based on your memory of the measurement.
If, during your blind listening tests you were listening to ordinary monopole point-source loudspeakers in optimal positioning and listening to the MLs positioned in the same place the test is not valid.
In my opinion only.
