Why Some Audiophiles Fear Measurements
Two comments re. amp'ish testing:
1. It must be done in-situ -- in the system -- for the measurements to be truly valid. This essentially echoes Ethan. I, and surely many others, have tested two amps that are virtually identical (within reason) on the bench that sound totally different in the system. I have always been able to measure differences once they were hooked up in the system to account for audible differences. In my experience, it's usually (not always) easier to measure differences that aren't heard than to hear differences not measured. Once the proper measurements are taken!
2. Again in my experience (IME) it is much easier to identify small differences by ear with simple test tones than with musical signals. For example, the level of IMD I can hear with a couple of test tones driving the system is much lower than I can hear in the music. The music keeps things "busy" and tends to mask low-level nonlinearities. The in-between case is when it's clear with test tones, doesn't seem to be heard with music, but things sound better when the nonlinearity is removed. There's a gradient from inaudible (but measurable), to audible but "masked" by music, to clearly audible.
All IMO - Don
I hope you could have a specific answer on what Orb ask you several " years " ago: validation on your four parameters hipothesis
There's nothing to validate. Those are the only four general parameter categories needed to describe everything affecting audio reproduction. Asking for validation is sort of like asking someone to "validate" that all colors are comprised of varying levels of Red, Green, and Blue. It is what it is, and that's self-evident. If you or others believe there are additional parameter categories, then please tell us what they are.
--Ethan
That's a great point Don. Anyone interested in assessing their audio system can do this easily with a basic freeware audio editor program, no fancy Audio Precision gear needed. You might not get THD and IMD results as hard numbers, but anyone can hear the 100 Hz difference tone when playing 800+900 Hz tones generated in an audio editor program. You might not even know if that 100 Hz difference tone was generated in the amplifier, the speakers, or your ears! But it's still useful to do such experiments.
--Ethan
OT: It really depends on what aspect of color you are talking about but mixing colors with red, green and blue can simulate all intermediate hues. However, I would not say that those intermediate hues must be mixes of RGB components as they are also all unique wavelengths of electromagnetic radiation. OTOH, we transduce (and perceive) them using, fundamentally, 3 color receptors optimized for red, yellow and blue.
--Ethan
Sorry, but you choose a very poor comparison. If needed any statement about colors can be validated by exact spectroscopy measurements using precise instruments and will never be considered scientifically unless experimentally proved. But as the concept of color is an approximate definition related to imprecisely defined wavelength intervals your statement is imprecise. Even your concept of "all colors are comprised" is not scientific language and is incorrect. Also it is not self-evident. Only people with good knowledge of color vision (eye and brain) can discuss it.
BTW, according the scientific method it is you who should carry the experiment and present the conditions and results for public scrutination.
I just wanted to add another thought. Anyone who wants to see how bad their room is should do a sweep from 20 Hz up to maybe 150 Hz at high SPL levels. Those rattling window frames can be considered equal to 50 percent distortion at whatever frequencies make them rattle. :D
--Ethan
Okay, whatever. The point is there are no other parameters than the four I listed, and after several years not one nay-sayer has ever been able to offer an additional parameter.
No, that's a logical flaw as I already explained. You can't prove a negative, and demanding that someone else prove a negative is improper. The burden is on those who believe there's more to prove what more there is. So whatcha got? :D
--Ethan
Ethan look back and you will see I was putting across two points;
1. Your 4 parameters are not necessarily the only ones involved with sound reproduction (we put both our points across so no need for me to reiterate them).
2. Test protocols with their respective measurements are highly focused meaning it is wrong to assume that existing presented measurements mean amps/preamps/etc are all transparent if well designed and built (you have argued the point in the past that audio gear is now built to a standard where amps and preamps should sound the same going by measurements)
By using 2 of your own parameters I have been able to argue the case IMO (and you now seem to agree with) that existing test procedures and their measurements may not be enough, hence the existing measurements do not provide the detail or scope to say amps (or other products) are audibly transparent.
And therefore this also comes back to; if the test procedure's scope and definition is not enough how do we prove with existing data that the only affects to audio reproduction (those descriptions mentioned by Jeff and a selective few more) are your 4 parameters.
My focus in the discussion has led to this point deliberately :)
Cheers
Orb
Cheers
Orb
All IMO - Don
I do not necessarily disagree Don.
But look at two very good power amps with very low output impedance and they can be audibly transparent and linear in their FR, run a real load simulation and this changes as shown by Stereophile.
I use this as a simple example, the other simple example is Nelson's complex IM distortion where he is using not two tones but I think it was 7 or 8 (and even this does not reflect a simulated real scenario), just curious have you managed to identify by ear IM distortion difference between two preamps where the worst individual harmonic distortion is around 0.02% for both just by using a couple of tones (key being products related to excellent existing measurement)?
Although again this goes against some of Ethan's points historically that measurements are more accurate than the ear (and is argued quite vocally by others in different forums - not suggesting Ethan is one of those).
Music is a problem in any test, bear in mind I did emphasise repeatable-trigger a specific response/behaviour/etc-worthwhile (only poster so far to mention this I think).
But without simulated scenario (all this is really is a realtime and practical version modelling) we may not fully see how two products differ but measure the same; as example the NAD and ARC I provided earlier.
I agree it is easy to find small differences with ok-good products but when we are talking the very good ones with very good design and implementation it looks like they would sound the same.
If necessary I could find more products that from existing measurements should sound the same but with very different topologies.
Thats why instead of actual music I am pondering a repeatable test with major chords at various points on the musical scale (this would not necessarily help to identify a behaviour-trait-problem but would potentially go towards being close to a real simulation).
I doubt you disagree with any of the above.
Cheers
Orb
I'm trying to follow this discussion between the two of you. Ethan has set forth 4 parameters and has invited you (and anyone else) to offer up another parameter, so could you point out what you believe to be the fifth and why?
I don't believe you have accurately set forth his position. If they sound different, it can be measured.
--Ethan
No one should be asked to prove a negative - but you are asked to prove a positive. You already suggested that you have experimental evidence of it, even based on listening tests, but you did not supply any verifiable details on it.
I respect objectivity and people who care about serious measurements and audio theory and models. But science with hidden data is not science, it is speculation. Speculation is a valid method, but it is nothing more than speculation.
Dear Ron: If you are not God and you tell me that today is Saturday when I think/know is Friday then IMHO I have the right to ask you: please let me know why today is Saturday? and when you give me your answer then you can ask me whatever you want about that Friday but first give an answer.
What if Ethan or any other person post: there are only three audio measurements that has audio validity. What could be your answer to that " absolute " statement?, think about.
I think that Ethan should give a precise answer because he is not God and could be wrong with out he aware on. If he does not have a scientific answer at least could comes here and tell us: " you can read here about where all is explained ".
If he can't do either then is almost useless and futile any dialogue with Ethan. Here in my country we say: " from tongue I eat 10kg. "
Regards and enjoy the music,
Raul.
Hi Ron, I am not being funny asking this honest :)
But what is your take on what I am saying in post #597 as it touches on your last sentence.
I think core to the discussion is understanding that a measurement is just generated data resulting from a defined test protocol/procedure with the relevant tools and their setup/configuration (this is explained in more detail in previous posts of mine).
BTW I cannot say what any other parameter would be, in same say Jeff states FR is not the only measurement in his article I linked before.
Also look back and you will say I cannot prove it so its just hypothesis (or speculation that is a better word as shown by microstrip) as much as Ethans.
I appreciate my posts are a right pain in the arse to read (even to me and I wrote them lol) but hopefully their context does come across possibly if read a few times.
Cheers
Orb
Actually Raul, today is Thursday except for our members down under and way around the other side of the globe ;)
Asking Ethan to provide evidence is, of course, a legitimate question. But if you're asking him to provide evidence of why there is no fifth parameter, then the logical fallacy arises, does it not?
Ethan has set more than that - he asserted values for at less two of these parameters - .1db 20-20kHz and -80db distortion for inaudibility. Unhappily we still do not have absolute values for them - these are relative values. You can not consider parameters without specifying their range and values.
If we have values it is possible to make an experiment trying to prove that there are other effects that can be heard.
Although not directly related consider the effect of dither noise in digital recorders. It affects only the LSB in 16 bit and it was proved to be audible.
Hope this does not annoy you but I am going to be very cheeky here :)
The use of "I Don't believe you have......" suggests that you have possibly made a judgement call and subconsciously communicated it.
I notice we tend to use "I believe" or "I don't believe" when we have not processed all the information that is mentally weighed up to arrive at a decision/judgement call.
I do the same myself, and if you look for it in forums its noticable how this mechanism kicks in, so take it as a bit of fun and cheek but keep an eye on how you and others use the believe context.
I laugh when I catch myself doing it, and it is always relating to what I describe above :)
When we tend to process everything presented, from my experience we either state it as an opinion or as experience/knowledge instead of believe (which we associate with the unknown or not enough information).
Cheers
Orb
This is something I touched in quite a lot of detail but appreciate my posts may suck bah.
It is not that he has to deal with a 5th parameter but validate his 4 parameters.
Validation requires taking other perception description (so far we have tone and bass explained by Ethan and are known how they work on FR anyway), but look back at Jeff's article/opinion Frequency response is not the only measurement as this provides a few other descriptions we use to describe what we hear in music.
So validation requires taking his parameters, checking multiple products with same and different measurements associated to these parameters and correlate those to a listeners perception (where trained to use the specific descriptive words).
This is a pig of a setup (due to the blind/dbt test protocol and definition but look at those done in other scientific studies or at HK for a feel).
So, as I also mentioned earlier the alternative would be the 1st step that uses specific reviewers and correlate their words to those measurements associated to his 4 parameters.
This would have to involve various rated products in terms of reviewer perception and also various measurements so a trend and then a model can be generated.
However the sticking point is subjective perception in any tests and even reviewers for Ethan and that in his opinion they are flawed.
But without any correlation between those 4 parameters beyond bass/tone for what listeners describe they hear and how it is affected (trend and behaviour) by different measurements (good and bad) we just have speculation.
I hope this helps but if not looking back goes into this a bit more, just rushing/summarising now as we are in a reiteration cycle of earlier posts.
Thanks
Orb
Cheers
Orb
Hmmm... Disclaimer: I am really not interested too much in this thread, despite appearances -- too debatable based upon limited/inaccurate knowledge, imo. Now to your points:
1. I left off test loads because I was lazy. In fact, you could argue a continuum from a simple static purely-resistive load to doing in-room measurements. In between those two cases will always be room for debate. Even done in-room that only answers it for that one test case (i.e. that one audiophile and maybe a friend or two if you are lucky).
2. I have not performed tests (listening or measurements) or preamps at that level that I recall, or anytime recently. Nor do I have any particular interest in doing so; I feel fairly certain I would be crucified no matter the findings. There are a lot of parameters going into such a test, such as what tones, what level, etc.
3. I do believe that measurements are more accurate than the ears. I can easily (well, with the right equipment and set-up) measure distortion spurs to below -100 dBFS and I really doubt anybody can hear distortion at that level. As I've said, I've been wrong before... I could certainly generate a number of tones and apply them to a couple of components then look at the output on a spectrum analyzer (or analysis system) and find the IMD products (and all the rest). Taking the right measurements in the right environment is the problem, IMO.
4. One of the biggest issues with music as a test source is that it constantly changes, making it very difficult to capture enough samples within a given time frame to get dow to the measurement noise floor. One solution has been to take a segment and replicate it, but of course there are end effects that must be compensated through windowing. The whole process gets complex and at the end you'll have the high-brows at one end trying to refine it further and the golden-ear crew at the other yelling it ain't real enough...
5. We are pretty sensitive to non-harmonic tones, which is why IMD is often considered much more important than THD. You can use as many tones as you want as long as you watch the loading so the peaks don't exceed the system's headroom. It might be interesting to start with two and a given level of IMD, then gradually add tones (carefully selected using prime numbers or e.g. IEEE Std-1241) and see where the IMD is masked. Repeat for a range of levels. Report back in a few weeks. Maybe an NPR (noise power ratio) test would be useful... Using musical chords (must choose the right scale, of course, otherwise you get non-harmonic tones, one reason it is tough to play with a piano) should show the same thing since our 12-note scale is based upon fractional powers of two. That is, a "nice" chord has only tones related to the notes in the chord and their overtones; a "bad" sounding chord will have other tones creeping in. As Ethan noted, if you pick the right tones it is fairly easy to hear the IMD tones -- they really do stand out (to our ears and our instruments).
6. I am running simulations now (well, at several GHz, but...) The list of simulations that could be performed is almost endless, but of course I eventually have to ship the product. I do not think it is all that hard to develop simulations or measurements showing why two products sound different; to my mind it is more often the environment at fault than the limitations of the equipment. One partial solution is to refine the test conditions, e.g. more realistics loads (see 1. above). The IHF and FTC have both worked at that, but of course there has to be a limit to the number of test cases.
So no, I don't think we disagree, but how far we can take this in the real world is always an issue. - Don
