Hello. It is me again.
Quick google shows the measurements of your speakers from stereophile:
It exhibits the same sudden drop there. Directivity problems there are tough to resolve. EQ may be able to help some but it may also make things worse.
Thanks for the replies, Amir. Yeah, the Sasha exhibits a peak in the 2k region which unfortunately is audible (being the region that we are fairly sensitive to...).
Why unfortunately?
I have a friend who owns Sasha's with an all ARC system and they sound great. The 2-4 kHz dip is intentional and is part of their voicing. Dave Wilson wants them to sound this waySee the spatial average (A64) in Martin Colloms room taken from the Hifi-Critic review - it will describe what you listen in a real room.
Even rivals such as Magico have a similar voicing in some speakers.
IMHO, if you do not like them, you should get some other speakers. Anyway you should compensate for the bass deficiencies - this will not change the character of the Sasha and will change your perception of the whole speaker.
Just one different opinion ...
It's a peak, not a dip.
How do you think I would compensate for the bass deficiencies?
Mad
Have you tried a sub in this system? ... Subs are not only to bring up bass but help even out the response in the bass thus better overall response. True it introduces another element of concern to the mix but .. Do try some subs with wide range of justment such as Jl Audio or Paradigm and see what gives ... You may be agreeably surprised.
Your friend's response looks a lot like DRC .. not that I am against DRC by the way...
Mad'
It would be interesting to see the response with the subs ... Also would be interesting to see how EQ on the subs would affect the overall. Iin my experience it does with excellent results. The EQ used doesn't have to be particularly involved or expensive. The Velodyne SMS-1 is good but I would have preferred a more flexible crossover. If you are in an experimental mood you could try , just to see, I am not suggesting you to leave it in your system (although you could because the results are usually good) the mini-DSP is a good place to start. The sheer cheapness of the solution ($125) is already compelling. You will lean quite a bit about the value of EQ in the bass, necessary in 90% or more of the cases. if the results are pleasing to you you an then substitute a better EQ.. Note that I am advocating to EQ only the subs ... the rest of the signal/system to remain untouched, unadulterated , unsoiled, un-messed with.
Below is my room response in green, with his room in purple.
Is it safe to assume using any of the above mentioned EQs for the bass is a better way to go than the internal automated EQ in the JL Audio F series subs?
