This whole thread started at the wrong end of the horse....
I'm not sure exactly what you want to accomplish with active, multi-amplification? Picking the right crossover is only half the battle. To quote Nelson Pass on his XVR-1 crossover: "Some audio products are designed so that you plug them in and you don’t have to fool around with them for a year before the system is greatly improved (but not this one) …." Here's Jim Smith's comment on Bi-amping: 'If I did this at all, I'd address almost everything else in this manual (Get Better Sound) first'. The answers you need to be successful require experimentation. They won't be coming from this forum.
I'd read the manual for the XVR-1 (link) so you understand how XOs work and what you'll need to do (skip over the middle part ppgs 3-16). It's the best discussion of the benefits and set-up of crossovers, not just his (Oh, XVR-1 can be multi-way). This is not like any other piece of audio equipment. Understand how they work and what you need before you buy one.
My thoughts: 1) It's expensive; 2) it requires a lot of time and patience; 3) Measurements (REW or similar) are mandatory, especially for a 3-way set-up. People don't do this which is why they end up worse than they started. Of course, if you just want to play, have at it!
I have made every mistake in the book on this, with the systems I've had for the past 50 years. I've spent $$$$s modifying crossovers. I've spent hundreds of hours changing filter paraments (XO points, slopes, Qs, and gain). I have spent even more time measuring results wih frequency sweeps, and listening to results.
Maybe I'm just a slow learner..?
You are on the right track with starting with something easy.
XVR-1 Manual
https://www.passlabs.com/wp-content/uploads/2020/05/XVR1_om.pdf
