Atmasphere Manufacturer May 4, 2010 3,439 2,910 1,860 St. Paul, MN www.atma-sphere.com Oct 6, 2025 #121 Kingrex said: My sub is very adjustable on its own so I will cut it off around 120. The woofers play from about 50 up to 600. The midrange is about 600 yo 1800. The horn tweetet is 1800 up to 20,000. Click to expand... At 120Hz the sub is likely to attract attention to itself, so it will likely need to be near the main speakers.
Kingrex Well-Known Member Feb 3, 2019 5,229 4,029 690 Oct 6, 2025 #122 Atmasphere said: At 120Hz the sub is likely to attract attention to itself, so it will likely need to be near the main speakers. Click to expand... I think its set around 70 or 80Hz now. It has the ability to go higher. I only want to leave options. Reactions: Atmasphere
