i doubt he has designed his amps to sound like SET.
The class Ds have a distortion signature that prevents higher ordered harmonics being unmasked- much like any good quality tube amp, but lower distortion (so more transparent) overall. We have enough customers that have ditched their SETs to know that it works. The goal was to make the amp sound like
music which is the same goal we have with our tube amps. Why make something sound like an SET when you can do better??
To my ears the Lamm SET amps do bass just fine
At some point you might try and see what happens when you filter out some of the bass. The Lamm OPTs are clearly much larger than an 18 Watt amp would otherwise need (compare to the size of output transformers in a Dynaco ST35 for example) so
its obvious that Victor was trying to increase low frequency inductance- evidence he knew very well the problem I've been talking about!
But the problem you're up against is not merely that the inductance is much lower at 20Hz than at 100Hz (and thus the load impedance on the power tube is lower as well, causing it to heat up as if it did not run hot enough already); the load line (a theoretical concept to set the tube's operating point) is
elliptical at bass frequencies, which causes the amp to make quite a lot of distortion. By filtering out bass the amp will simply do its
strengths that much better.
Thanks for confirming the sound character differences, no one should buy a Class D amp, even the Atmasphere, expecting SET sound.
One of the few things upon which we agree, but for entirely different reasons.
My in-room RTA measurements show my bass goes to 20 Hz…with a SET.
But not at full power, and the bass was causing the amp
much more distortion, which impedes detail. To do full power your output transformer would be the size of a hotel room refrigerator and would have no HF bandwidth.
Notably, its the bass region where most of the power of musical information lies. There's a lot of lower frequency content that most people don't even know is there, and this is worse if you play LPs due to warp.
The SETs that Ron was using at last report actually runs dual output transformers driven by independent power tubes with their resulting outputs paralleled. That technique helps limit the size of the output transformer while still allowing for greater power.
Its clear that the designer is well aware of the bass limitations I've been talking about.
Many lower performance SETs have a problem but the best ones do not.
All lower performance SETs have a problem and so do the best ones. You can make outlandish claims like this but they are only that and nothing else; when the rubber meets the road there's no SET ever made that can play 20Hz at full power (clipping). That's hard enough for a regular PP tube amp to do!
@Ron Resnick Have you been able to set up the bass filter for your amps as we discussed?
Feedback is like lead or mercury, no safe amount…
...if improperly applied. Do it right and it works really well. The trick, in case you're interested, is to do it in the same manner as seen with opamps, which is to say you treat the amplifier as an opamp and apply feedback externally around it. This technique prevents the feedback signal being distorted by non-linearities at the feedback node, since resistors are far more linear than active devices such as the cathode of a tube or base of a transistor.
In the tube world, something called '
Schade feedback' is a similar concept.
If you had tougher speakers, then the 4 ohm tap would probably be the best choice (although in practice I have found the 8 ohm tap always seems to sound better) and then you have rather inconsequential swings.
On
any tube amplifier, the OPT is less efficient with lower impedance taps. You can
easily lose an octave of bandwidth between the 4 Ohm and 8 Ohm taps on this account; ask any transformer designer. If the OPT has a 16 Ohm tap and you have a 16 Ohm speaker, since the turns ratio is considerably reduced between input and output, the result is even wider bandwidth, but you need a 16 Ohm speaker to really take advantage of that. That is why 16 Ohm speakers were more common in the 1950s and prior.
@DasguteOhr has made some very insightful comments on this page regarding the load sensitivity issue, literally describing what the issue is when you mix
power paradigm and Voltage paradigm technologies (any zero feedback tube amp is power paradigm). The 'standard load impedance' model that Stereophile uses demonstrates amplifier weakness in this regard- the amp reacts more if its output impedance is higher.
The impedance curve of the speaker
must be known if you are to get the
best out of a zero feedback tube amplifier!!
