Start wherever you like with that list - cant go wrong if serviced and in good condition.
View attachment 140543.
My starting point, more to follow mmmmmid 2025 I hope.
Very nice table and arm. What cartridge is that?
Thank you Peter, its a slightly renovated Russ Collinson plinth, 3012R arm and a lovey re tipped SUPEX and enjoying very much!
Regards Stephen
When I did my Garrard this time last year Russ Collinson was no longer doing plinths. I got mine done by Carl Ellis in Manchester and the lacquer finish done in London.Excellent stuff.
These days, Russ Collinson has so many followers on youtube that I think it's hard to get him to take orders.
My garrard plinth is one of his layered solid cherry wood ones. Shindo copy.
I believe the cabinets for my grf corner horns may be done be him too.
I think the problem is that you can get very good plinths online from Europe and also made in the UK very cheaply. Of course lots of people DIY, which is half the fun.A most excellent Shindo copy too I understand but I also think he is no longer making plinths but using his skills elsewhere. As for those corner horns with hand built Abbas crossovers to boot, well that would be interesting if Collinson made the Horn Cabinets as I understand he builds furniture now so very possible. I may be wrong.
I managed to find my plinth second hand. An early and well used square cornered model. Now with a little more polish and shellac and cut outs made for an SME and an additional arm-board for later additions.
Replacement of the mainplatter by a non magnetic one is recommended otherwise you limit yourself in the cartridge choices, also the sonic improvement is well worth.I purchased a restored Thorens TD 124 MK1 from STS turntables in 2015 for 2459.00. I sent it to Schopper for a tune up assessment (5200.00 to include full chassis/mortor restoration and replacement of both the top platter and main platter; 4525.00 if I elect not to replace the main platter). My main platter is ok (but it is magnetic…& likely contributed to the damage when I tried to remove the top platter for general maintenance). The price also includes a replacement walnut plinth (not required but the one I have isn’t as aesthetically appealing). I’m leaning towards the Schopper refurbishment. I’m thinking this will be my final modding of the TT as I’m nearing 60 years old. Is it routine to dump large sums of money into these idler tables every decade or so to keep it running optimally?
What exactly do you mean with ,,noise,, were do you come from ?As aforementioned…possibly not articulated clearly… there’s always been some noise with the restored TT..& the top platter was recently warped. I wanted a full assessment after a decade of use. I was going to send it back to STS in Tennessee…but I didn’t get a reply back when I contacted Greg by email. I saw Schopper touted as the one to bring the TT to the next level among pro restorers. So I thought ‘what the hell…why not?’…worst case I could do nothing and have the table returned untouched.
My question…albeit subjective and broad in scope…is…have ‘others’ out there…who’ve done the Schopper upgrades…found it to be ‘notably worthy’…primarily in reducing the operational noise heard from the TD 124 MK One version? If so…how so?
If you want to increase the performance, you have to remove the Quickstart aluminum platter and put an 8mm thick graphite or Tizo turntable mat on the original green cast platter. No more magnetic influence and the original platter sounds, as promised, better than all replica platters.Replacement of the mainplatter by a non magnetic one is recommended otherwise you limit yourself in the cartridge choices, also the sonic improvement is well worth.
What I not well understood why sending a revised turntable again for a next revision?
important for smooth running, overhaul the motor, adjust, check the bearing ball for wear.As aforementioned…possibly not articulated clearly… there’s always been some noise with the restored TT..& the top platter was recently warped. I wanted a full assessment after a decade of use. I was going to send it back to STS in Tennessee…but I didn’t get a reply back when I contacted Greg by email. I saw Juerg @ Schopper touted as the one to bring the TT to the next level among pro restorers. So I thought ‘what the hell…why not?’…worst case I could do nothing and have the table returned untouched…if I found it to be cost prohibitive.
My question…albeit subjective and broad in scope…is…have ‘others’ out there…who’ve done the Schopper upgrades…found it to be ‘notably worthy’…primarily in reducing the operational noise heard from the TD 124 MK One version? If so…how so? Schopper states ‘after our restoration, all problems also with noise level will be gone’
Footnote: I’ve never experienced any issues with MM or MC cartridges on the table with the magnetic platter in place. I use a Dynavector model 20x2 Low.
You can send it to Chris Harban Woodsong recommendedAs aforementioned…possibly not articulated clearly… there’s always been some noise with the restored TT..& the top platter was recently warped. I wanted a full assessment after a decade of use. I was going to send it back to STS in Tennessee…but I didn’t get a reply back when I contacted Greg by email. I saw Juerg @ Schopper touted as the one to bring the TT to the next level among pro restorers. So I thought ‘what the hell…why not?’…worst case I could do nothing and have the table returned untouched…if I found it to be cost prohibitive.
Ignorance + conviction = lethal combination.I do not understand the fascination for idlers, they were made for quick start and stop for radio stations , and not for a rumble free sound. All kinds if problems, and obsolete technology when DD arrived. EMT are ok but nothing I want, yes I heard some..
When I run across your posts in various threads I don’t find much you do like…I do not understand the fascination for idlers, they were made for quick start and stop for radio stations , and not for a rumble free sound. All kinds if problems, and obsolete technology when DD arrived. EMT are ok but nothing I want, yes I heard some..
