He finally caved in .He does not post much anymore, it looks like he is selling a lot of his equipment. Maybe he is going all Horns /SET![]()
@andromedaaudio
Does it make sense to offer both the classical 3-way and these?
What are the pros and cons of both?
Nice, I like passive speakersA passive sub with 12 inch woofer is on the way .
Nice, I like passive speakers![]()
I will have 3 models in the end :
Next year , 2025 they go up for reviewing / advertising
The 3 way floor stander with front firing 8 inch woofer .( model 1 )
The 3 way with side firing 11 inch woofer ( see above post ,Model 2 )
A passive sub with 12 inch woofer is on the way . 92 db eff.
( And the XPE model on request )
A high mounted side firing woofer gives a different dispersion / radiation pattern , i like it a bit more i think .
There are no cons of either model , the higher you go up in the range the more bass output you will get .
Model 2 has more internal volume combined with a 11 inch woofer and 7 inch mid ( high freq units are the same )
A speaker which goes both lower and has more membrane surface will be able to scale up more /produce a bigger sound
Model 1 can be combined with 1 sub
Model 2 needs 2.
Larger woofers but same mid/twt ?
Probably one of the best midrange speakers ever built in my opinion.
definitely sound and bandwidth 12db/xover 300hz to 6khz 3" inch dome
Scan-Speak Ellipticor D8404/552000 Dome midrange kaufen
Bestellen Sie den D8404/552000 online bei SoundImports ✓ Versand am selben Tag ✓ Kostenloser Versandwww.soundimports.eu
Well, each of his speakers consists of a 4x 15"WE 38 woofer two per side (6.5k), 2x9" midwoofer (1.2k), 2xdome tweeter front, one in the back(1.8k). I don't think that's expensive if he later offers everything for 30k€ a pair as a kit with xover.
His website, i'm waiting for price
Oferta
akustyk.com.pl
sorry for saying this, I would never think of using a diamond tweeter or ceramic driver, I find them horrible. I'm old school.Price/ complexity doesn t automatically result in better SQ .
I learned my lesson the hard way .
I did spend 4 K for a pair of diamond tweeters at one time
