That would never be consideration for me.This DAC sounds promising. Has anyone compared it side by side with a good turntable system?
Stirling starts with digital and ends with analog. At least that’s what he did with the CH Stenheim in London, and I believe he would have done for dcc’s Stenheim as well.
The digital would have helped the speed to get there, but by no means is sufficient or necessary.
Either way, if some set up expert did only digital, he will be successful surely given the audiophile profile, does not mean he is correct. You can get there by measurements alone sometimes, does not make it right not to also listen. There is an overlap between what is correct and what is not, it is not a mutually exclusive Venn diagram
with digital the media is 'wanting'.......not robust......in terms of degrees of sounding real. so as our technology is approaching digital's ideal it seems to really reward over-the-top approaches to noise and power supplies. tiny incremental steps matter and we can hear them. it's one reason we use digital to set up systems, it tells you clearly the slightest restrictions. analog is not nearly as sensitive to not being perfectly optimized.
the CD media seems to be a little better by degrees with this, but with files or streaming it's extreme.
so when you see Wadax with all it's exotic chassis shapes and mass, very large heavy power supplies, crazy spendy DC cables......then read about all the stuff Taiko is doing lowering noise with the Olympus efforts just for the server......what dCS is doing is simply staying with that trend. and it will likely get more that way than less. with the Varese i was actually surprised there are not separate added power supplies, or even interfaces to add them later. it's just the way it is chasing ultimate digital. one piece 'simple' chassis digital can't compete, and is not sufficiently relatively future proof. maybe a trickle-down piece like the Wadax Studio Player might be one answer that does some of that. i'm sure there will be a dCS version of that based on the Varese technology at some point.
the good thing is the ease of use of digital and musical access makes up for it's fragility and cost/complication of all the chassis pieces. so the experiential equation chasing great digital performance makes it worth it to some.
Huh? 13 digital cables, 4 power cords, interconnects, plus each box 30-50 pounds... haha, not a very portable set upFor setup folks, there are real advantages to digital playback.
1. You can easily carry the gear unlike a turntable.
Huh? 13 digital cables, 4 power cords, interconnects, plus each box 30-50 pounds... haha, not a very portable set up![]()
I marvell at the mechanical complexity of that machine!Not always
Not always
Not sure why you said that…That would never be consideration for me.
The post I commented on asked whether anyone compared the Varese to a turntable. If you would like I can briefly elaborate on my "not a consideration" response. Bottom line, life is too short to fiddle with vinyl. I do not enjoy jumping up every 10 to 20 minutes to flip sides or skip tracks. I don't want to clean or have to store X amount of albums. It is bad enough that I have to store and retain the original CD's I have burned as music files. Unlike LP's that I might want to play, these CD's can be stored anywhere and do not need to be kept in close proximity to my music room.Not sure why you said that…
Actually, I enjoy doing just that - but I do understand your point...I do not enjoy jumping up every 10 to 20 minutes to flip sides or skip tracks.
Apart from being heavier than CDs, they offer (to me) lots of fun reading the sleeve notes and admiring the artwork... Being lazy, I rarely clean my LPs other than when I first purchase them.I don't want to clean or have to store X amount of albums.
Indeed, music comes first and good sound makes listening to music a more enjoyable experience.I will let others debate any SQ differences they attribute to the two sources.
LikewiseI grew up with vinyl and RtR.
Noted. I am not interested in a rehash about how convenient digital is or its pros and cons vs analog.. there are tons of threads on those to read. At $300k, i will very curious to hear how it sounds compared to a good analog or turntable front end..The post I commented on asked whether anyone compared the Varese to a turntable. If you would like I can briefly elaborate on my "not a consideration" response. Bottom line, life is too short to fiddle with vinyl. I do not enjoy jumping up every 10 to 20 minutes to flip sides or skip tracks. I don't want to clean or have to store X amount of albums. It is bad enough that I have to store and retain the original CD's I have burned as music files. Unlike LP's that I might want to play, these CD's can be stored anywhere and do not need to be kept in close proximity to my music room.
I will let others debate any SQ differences they attribute to the two sources. I grew up with vinyl and RtR. Thank goodness I don't have to deal with it these days to get great sound.
I am sure that as more individuals have the opportunity to hear the Varese you will get their opinions as to how it sounds compared to analog. I did not have to wait for the release of Varese to form my opinion. Varese would get me closer to what I want from this hobby. The price of entry is probably something I am not comfortable with.Noted. I am not interested in a rehash about how convenient digital is or its pros and cons vs analog.. there are tons of threads on those to read. At $300k, i will very curious to hear how it sounds compared to a good analog or turntable front end..
Well that's surely not a universal opinion. You can have any opinion you want, does not make it correct.Vinyl is a superior medium.
Getting up every 20 minutes is actually really good for your health! About the worst thing that streaming does is make audiophiles into couch potatoes. I’ve discovered the joy of listening to music while walking around. I don’t feel like I’m trapped into my listening chair with my head in a vice obsessing over silly trivialities like whether an instrument comes from one channel or another or what its soundstage is, although I dabbled in such foolishness when I was much younger and read too much of HP’s writing in TAS. The issue of vinyl vs. digital has been debated ad nauseam on WBF but vinyl has survived and is thriving against all expectations. I never imagined vinyl outselling CDs by orders of magnitude in 2024, but here we are. 8-year old kids are marching into record stores to buy the latest Taylor Swift vinyl album in their favorite colors. Put that in your pipe and smoke it. Who’d have thought that would happen?The post I commented on asked whether anyone compared the Varese to a turntable. If you would like I can briefly elaborate on my "not a consideration" response. Bottom line, life is too short to fiddle with vinyl. I do not enjoy jumping up every 10 to 20 minutes to flip sides or skip tracks. I don't want to clean or have to store X amount of albums. It is bad enough that I have to store and retain the original CD's I have burned as music files. Unlike LP's that I might want to play, these CD's can be stored anywhere and do not need to be kept in close proximity to my music room.
Vinyl is a superior medium compared to digital for a more engaging musical experience, in my opinion. Granted, I have not heard a $300k digital system yetWell that's surely not a universal opinion. You can have any opinion you want, does not make it correct.
Hi Jim,Well that's surely not a universal opinion. You can have any opinion you want, does not make it correct.
Vinyl is a superior medium. It allows the listener to dive into the music, connecting with the performers. My vinyl setup allows this easily, even with poor LPs, my Vivaldi Apex suite finally comes close when using the best SACD has to offer (supported by a plethora of eye-watering expensive cabling, bases, power management, grounding etc... Yes, that paraphernalia benefits vinyl too, to a lesser extent; without it, I cannot listen to digital and enjoy it). The secret of vinyl is that this "bonding in music" takes place even on relatively simple, modestly priced, rigs. Hence the resurgence of LP as a music medium (including the joys of cover art and notes).
Interesting point. And I have pondered it.That resurgence is for the very most part fed by digitally sourced LPs (digital recording and/or digital mastering). Thus there is a problem with your logic regarding the alleged musical inferiority of digital.
If the "bonding in music", as you say, can then take place as well, there cannot be a problem with digital per se. What in that case then helps the communication of music would be vinyl colorations upon production and/or playback. In addition, or alternatively, the different mastering required to make music suitable for vinyl production, given the limitations of the medium, would help.
Any or all of these would then be "the secret of vinyl" that you talk about.
