... the omni's do not do well in small rooms but wins best-of-show accolades in larger exhibit rooms (i.e.: Munich in 2022 & 2024 but not 2023).
Last word: my experience (and opinion) is diffusion over absorption. The more diffusion the better to the point that absorption should be used only to treat specific room problems. Diffusion preserves the reflected signal (very important!) but essentially lowers its level to achieve a higher direct-to-reflected ratio.
I agree to both.That has been my experience as well.
Too much early-onset reflection energy degrades clarity and image precision. But the SAME amount of reflection energy arriving after a sufficiently long time-delay does not have these drawbacks, but instead is interpreted as "spaciousness". Imo spectrally-correct, late-onset reflections can act as "carriers" for the reverberation tails on the recording, such that under favorable conditions the venue spatial information on the recording becomes perceptually dominant, resulting in a "you are there" presentation.
Agreed. Unless it is truly broadband, absorption alters the spectral balance of the reflections, removing more of the high frequency energy. Ime timbre is richer and more natural-sounding when the reflections have approximately the same spectral balance as the first-arrival sound (this being imo one of the reasons a good omni in a good room sounds so delicious). And ime listening fatigue can set in when the spectral discrepancy between the first-arrival sound and the reflections is too great, especially if those reflections arrive after only a short amount of time.
Thanks for the book hint. Sounds interesting. But I doubt that it will cover the specific case of omnidirectional speakers.Emperyan: I have my C'points 1m from the side walls and 2.5m (unequal distances) from the rear wall but, my room is less than ideal. Because my room is too small, the listener position is closer to the speakers.
I cannot speak to proper time delay; however, the book Sound Reproduction (Floyd E. Toole) is the best reference and a wealth of information regarding room acoustic-loudspeaker interaction.
So the question for home use would be, how much time-delay is ideal. What´s the ideal range of distance an omni speaker should be placed from the back wall and from side walls? Would be awesome to hear from people who have experimented with different placements and distances. Unfortunately, I am not very flexible in this regard in my living room.
That equates to 3.5m to a wall and another 3.5m from the wall to the listener (if first reflection and equidistant).
Forgive me if I digress; but, it does bring up another question: should the ceiling reflection be the same total distance as the first wall reflection (i.e.: arriving at the same time)?
Zoltan, I look forward to seeing you as always if you will be attending the show. I also look forward to experiencing speakers again. This is a must-see room at the show for those who have not heard them.
Unfortunately, we won't be going to CAF in Washington this year, but my speakers will be there with Thomas (AV Luxury Group) .Zoltan, I look forward to seeing you as always if you will be attending the show. I also look forward to experiencing speakers again. This is a must-see room at the show for those who have not heard them.
Can you change the height of Bayz speakers?In my room, the Counterpoints were setup about 66 inches from the front wall, and also about 66 inches from the sidewall. I have natural wool carpet with an acoustic fabric between the carpet and the pad, and I have a suspended ceiling cloud. Room height is 9’6”.
With the Bayz “tubes” being ported, finding the right orientation and position to achieve the best bass response was the prime factor in setup, I never found myself paying attention to the reflected energy. I’ve seen them setup pointed straight back to the front wall, angled like I ended up with (aimed into the corners) and even oriented so the ports aimed to the center of the front wall. In my case (similar for other rear ported speakers in my room) pulling the speaker further into the room reduced the perceived bass depth, pushing them back muddied the bass and produced some boom-y-ness.
The location of the Bayz radial membrane isn’t really a factor in setup, its all about getting the bass dialed in. Getting that settled takes a little bit of time and effort, but the speakers are easy enough to move about with some furniture slides under the footers.
I had Courantes in the room before the big Counterpoints, and the larger speaker filled the room with ease, the smaller Courante I think would have been better in a smaller room than mine (roughly 19’w, 29’L, 9.5’h).
Zoltan, don't worry. I will keep an eye on TK, as his room is right down the hall from oursUnfortunately, we won't be going to CAF in Washington this year, but my speakers will be there with Thomas (AV Luxury Group) .
ROOM 803
Speakers: Bayz Audio Courante 2.0 $ 47,900 - $ 69,900 / pair
Amplification: Burmester 218 Reference Stereo Amplifier $ 50,000
Burmester 088 Pre-amplifier $ 33,000
Digital Source: 1. Aurender N20 Ultra High-Performance $ 12,500
Network Transport Music Server / Streamer
2. Berkeley Audio Design Alpha DAC $ 28,000
3. Berkeley Audio Design Alpha USB Re-clocker $ 2,495
Digital Cables: 1. Shunyata R. Omega 1.5 meter USB Cable $ 2,800
2. Shunyata R. Omega 1.25 meter AES Cable $ 3,800
Analog Cables: 1. Shunyata Sigma X 2.5 meter Speaker Cables $ 12,500
2. Shunyata R. Sigma X, 1.5 meter XLR Cables $ 5,180
Power Cables Shunyata R. Sigma X 1.7meter NR Power Cords $ 4,000
Power Distributor Shunyata R. Denali 6000T/v2 Limited Edition $ 7,000
AV Rack Solid Tech Hybrid Shelf $ 4,800
Zoltan
Not really… the photos show two different models. The larger CounterPoints, and the smallerCan you change the height of Bayz speakers?
The two photos show different heights (looking at the base). How tall can they get or what is the maximum height of Bayz speakers?
