Wilson Audio or Zellaton
Well, you are right: there is a big conspiracy against WA here.
Conspiracy is why you never uploaded the final set of videos with Gryphon, and with the WA.
I’ve uploaded one video with Gryphon and Grandi. It’s on my channel. It’s not final, will do more videos after I come back from vacation.
Reactions: bonzo75
You can't generalise this with the Grandinote speakers. They are not exact high efficiency because you are not running them with 45, 46, 2a3, GM70, etc. You are running them with Jadis and Gryphon.
Why running them with GM70 qualifies and with 845 tubes is not relevant? They are both high power tubes as opposed to 45, 46 and 2a3.
Are you using the Jadis 845 with only the 20w in class A? If yes then fine.
But they respond better to gryphon? Will listen to the video tomorrow. If you are finding that Gryphon drives them better than Jadis, it just means they need that grunt. The Grandinote amp too seemed to have an advantage over them in control
