16,224
13,690
2,665
Sorry, guys, but the shiny floor is the Koster Vap water sealant layer which will be covered by grey wool carpet and walnut wood flooring in the listening room.
Hi-FiGuy
2,241
763
385
Well darn, I love shiny tinted concrete floors.
Not much for acoustics though.
Its good to see progress.
What is your time estimate for completion? Months or years?
months — I hope
JackD201
1,429
1,820
Manila, Philippines
It is very interesting to hear how much quieter the whole space "sounded" with this blue jeans insulation installed:
Ron you might singlehandedly cause a shortage of cotton for the printing of dollar bills! LOL
Great to see the progress!
16,224
13,690
2,665
Thank you, Jack!
I am now soliciting final advice from my acoustic advisors before we make a decision what to put on the cinder block and the wood framing.
audioquattr
307
413
280
Netherlands
CURRENT THINKING*
tonearms/cartridges
Certain: ZYX UNIverse Premium on NOS SME 2012R
Considering: Koetsu Rosewood Signature Platinum or Benz Micro LP-S MR on Acoustical Solutions Axiom
Amplifiers
Alieno LTD 250
AM Audio 833S Ultra
Jadis JA-200 Mk. II
*Subject to change in the next ten minutes
Good thinking Ron :)
CURRENT THINKING*
LOL
Room building process is also making steps, good to see !
16,224
13,690
2,665
Hi audioquattr! Do you know anyone else who has purchased an Alieno?
Bobvin
1,720
3,078
665
Portland
www.purewatersystems.com
Nice to see Ron. Even after you install the sheetrock, there will be some added “weight” to the sound in the room. Not “darker” but just a visceral sense of mass. Like closing the door of high quality automobiles, there is more “there” there.
16,224
13,690
2,665
I learned last night that I may be overly pessimistic with regard to a tube noise concern about the Io if I use a .2mV (3.54cm/s) Koetsu cartridge. Jim White does not use vintage tubes but his new production tubes are apparently quiet enough to handle a .2mV MC cartridge without excessive noise (for tube devotees).
I was also told to achieve the best high gain/low noise compromise by using the second to the highest gain setting on the Io (providing I use a line stage as well). I am pretty excited to get Jim’s Eclipse level stuff into the system! (My early Io with one power supply was upgraded only to the Signature level way back when.)
16,224
13,690
2,665
I have a question, gentlemen. How the heck am I going to "hatch" this system all at once? It cannot happen all at once. (I hate that I am going to be deprived of the system evolutionary joy and fascination of adding just one new component at a time over months and years into an already well-sorted system.)
Someday, if the house is repaired, and the listening room is finished, and I am ready to take delivery of the Pandragons, how can I set them up? I cannot play the speakers since I have no source.
If we install the turntable first, then I have no speakers through which to listen to music.
If I do not have a turntable I will not be able to install the six (6!) new Aesthetix boxes.
So I am thinking 1) first to resuscitate the VTLs and un-box and dust off an old Musical Fidelity kW tube SACD player first.
2) Then install the Aesthetix Io and Callisto, plugging the SACD player as the source into the Callisto line stage.
3) Then install the speakers.
4) Then bring in the turntable
Does this make sense? Is some other sequence more logical or prudent?
16,224
13,690
2,665
It cannot happen all at once, because I am starting with nothing. (I hate that I am going to be deprived of the system evolutionary joy and fascination of adding just one new component at a time over months and years into an already well-sorted system.)
Someday, if the house is repaired, and the listening room is finished, and I am ready to take delivery of the Pendragons, how can I set them up? I cannot play the speakers since I have no new source component and no new pre-amp.
I want to introduce each new component one by one (even if it is rapidly or the same day) to make sure such new component is working.
So I am thinking:
1) A) Resuscitate the VTLs and B) un-box and dust off an old Musical Fidelity kW tube SACD player and C) un-box and dust off a pair of Dynaudio Contour bookshelf speakers to be able to hear something. This will let me test the VTLs. (I can use my EVS discrete resistor attenuators to control the VTLs into the SACD player.)
2) Install the two Herzan equipment racks for the Aesthetix boxes. Then remove the attenuators and connect the Aesthetix Callisto, plugging the SACD player as the source into the Callisto line stage, to test the Callisto line stage.
3) Then install the Pendragon speakers in place of the Dynaudios. At this point I will be able to play SACDs through the Callisto and drive the Pendragons with the VTLs.
4) Then bring in the turntable, and connect up and test the Aesthetix Io. And remove the SACD player. This would mean all of the new components are in place.
Does this make sense? Is some other sequence more logical or more prudent?
Folsom
6,030
1,503
550
Eastern WA
I think the wait is driving you mad. This reads more like philosophy than anything else.
If the room is done, put the Pendragons in. Start connecting stuff. If you have a used version of something install it till you get/decide what you're really going to use.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
So I am thinking:
if I were you, how i would approach this would be to install the speakers first. when those are in place, borrow an integrated amp (can be very basic, could buy it used and then sell it), and maybe one with a dac, and use your laptop to play music. it's so simple to do, and will give you music, and allow you to get a feel for things. lots of people can help you and even provide some hard drive tunes if necessary (like me).
maybe even bypass the bass towers initially until you get that far. they can just sit there.
then you can add one variable at a time and bypass parts of the integrated as you go along. you will even get a feel for system evolution as you step up into your new big rig.
bonzo75
22,650
13,688
2,710
London
Speakers first, keep digital constant to evaluate amps, then add the TT. Once the analog settles down you might need to reevaluate amps again. Cables at the end.
jeff1225
3,013
3,266
1,410
51
I agree with Mike. Buy a NAD amp.. There's a NAD 372 on Audiogon for $500 right now, you'll have 80% of the musical enjoyment and can build the system up from there.
16,224
13,690
2,665
Thank you all for your thoughts! :D
I have an Arcam A90 integrated amp. (I have three of them, actually, for two bedroom systems and a living room system.) I could use that.
Not meaning to drive y'all crazy but there is no way I am going to fire up the VTLs after they make a bumpy 50 mile trip back from being resuscitated at VTL connected first to the Pendragon ribbon drivers. I don't see any harm in powering up each resuscitated piece and each new piece first with stuff I can afford to blow up/lose. That is why I want to hear music from the VTLs first with the Dynaudios before I connect the VTLs to the Pendragons.
And if the VTLs work reliably then driving the Pendragons with the VTLs probably will teach more more about the Pendragons right away than would an integrated amp, no?
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
depends all on logistics and timing. agree if you can use the VTL's in a quick time frame then you don't need an in between step. but once the big Gryphon's are in place, if you need flexibility and don't want to deal with the VTL's but want music then you have the choice of the Arcam's. stay flexible.
I have a set of ICE based 'Chinese' class D 500 watt Rowland clones upstairs I can always throw into the breach if I ever have a need. it's my back up with little investment and actually preforms quite nicely. reality rears it's ugly head from time to time. and i'm never without tunes.
in your situation the big Gryphon's are the 800 pound Gorilla.......once those are in place the rest is quite easy (maybe excepting the AS-2000). so get those Gryphon's going and then go with the flow. and you get to hear and see those big boys. it easier installing the Gryphon's without anything else in the way too.
16,224
13,690
2,665
That makes perfect sense, Kedar, Mike, thank you.
The VTLs are the only things not in inaccessible storage, so I can drive them to VTL and get them fixed a month or two before the speakers are set up or anything else arrives. I just do not want the Pendragons to be the first speakers to which the VTLs are connected when I power up the VTLs back in the house after I retrieve the from VTL factory.
4,704
That makes perfect sense, Mike, thank you.
VTLs are fuse protected and have an output transformer - IMHO you can connect them without any risk to your new speakers. Although I never connect an unknown solid state DC coupled amplifier to my speakers without first measuring it looking for DC, I never go though these procedures with transformer coupled amplifiers. At best I switch them on and keep my hand close to the switch for two minutes.
XV-1
3,620
2,638
1,860
Sydney
Speakers first.
The last thing you want is preferring the Dynaudio Contour bookshelf speakers over the Gryphon Pendragons :eek::eek:
