Zellaton and my ascent to Soulution
"Hello everyone.
Two days of testing with the 727 preamp.
In the end, the 727+717 combination is truly wonderful.
The control increases further, and the feeling of greater body when listening to instruments makes them more real. It's difficult to describe the exact sensation, but I hope you get the idea. The depth and openness of the soundstage are first-rate. The volume levels aren't exceptional, in the sense that there's no middle ground on the scale, neither too low nor too high. In any case, it's an excellent preamp, the best I've ever heard."
Problem solved :)
Thank you my friend.
Nick
I have few questions, I will apriciate your answers.
- why 717 have 2 pairs of XLR inputs?
- why Soulution is having 2 power amps available (711+ and 717) mostly having the same characteristics?
This can be used for bridge mono operation mainly.
711+ is an upgrade to the 711 where the 717 is a newly developed product which essentially replaces the 711.
Hope that helps.
Hope that helps.
Also, I assume to connect some DACs and Phono Pre's directly without a Preamp. The 717 comes with a remote control for selection.
Well, yes. As long as the their up to the job :)
C'è qualcosa che non va con i 717 e che nessuno, per qualche motivo, vuole condividere. Sono appassionato di questo hobby da molto tempo e non è mai una bella cosa quando un prodotto tanto atteso arriva sul mercato e il mare diventa completamente silenzioso.
It's easy for an owner to say it sounds good, but I'll try to give an unbiased opinion. I'm using a Burmester 911 with its 808 preamp, a wonderful combination, but in my setup with my Violon VI alto a cappellas, it sounded a bit too bright. I recently switched to FM Acoustics preamps and power amps, which are beautiful and sound wonderful. I sometimes use the Select as a preamp for the power amps, but something always feels missing from the music. Finally, I got around to using the Soulution 727 preamp with the FM Acoustics 111 power amps, and I did that for about a year. I gained detail and speed, then I added the Zellaton Plural Evos, a huge improvement. Finally, I recently had a chance to listen to the 717 at home and immediately knew it would be my power amp. Here's what the 717 offers: absolute linearity with a wide soundstage, plenty of detail, the rhythmic base is always correctly present without invading the midrange, no listening fatigue, infinite power when needed. On the downside, it does get quite warm. Happy listening, everyone.
Guys, please be so polite to talk in English :)
quite the progression of wonderful gear. thanks for that.
Reactions: vinyl_mike
Thank you for the above. How should we interpret the performance of the 711+ versus the 717?
We're rather new partners to Soulution where I have no direct and deep experience with the former 710 and 711 power amplifiers.
The 717 has been newly developed from the ground up though and communicated as something rather different and clearly superior while still being based on some of the core Soulution principles like wide bandwidth, phase coherence, low distorsion and the use of their own switch mode power supplies.
So how did Mike M return a $240k set of SOTA, new amps in the US weeks after introduction and end up with a pair of $150k Stellavox without losing his shirt? This would be at least a $50k loss for most audiophiles. Let me guess why…
The 717 are $240k?!!!!! Yikes!!!!! I thought the stereo version was like $70-75k or so.....
Asked and answered.
You really need to take a relax Keith
Reactions: Kvali1
I am not sure what you’re implying here . First of all, Mike is allowed to do whatever he wants with whatever gear he chooses . He has had more top gear than most people on this forum. For decades he’s built his reference sound system down to the details . I’ve been to many rooms and his is top notch. So when he makes big decisions like changing amplifiers we should all pay attention. No one is strong arming him one way or another . He’s a purist , chasing the perfect sound .
I know nothing of the fiscal considerations , nor do I care . He’s plainly sharing his journey with us .
You don’t have to like it or agree , but don’t insinuate any BS back deals .
You’re more than welcome to
Try 717 and stellavox too if you can afford it.
If you can’t , then just dream about it, like the rest of us.
What?!!!!
because I'm tired of all the shilling, back room deals, and blatant quid pro quo here. it's so obvious to many of us who have been around the block. I've received a dozen texts and PMs all saying the same thing. how many dealers have y'all warned from this forum for selling gear behind the scenes but you allow this to happen with AudioArts.
let's see some transparency on all of this - to his credit, Mike L gave some.
