These days I take umbrage to the word 'dynamics' which has always vexed me. IMO, IME when that word is used, in 95% or greater of audiophile conversation, you can safely replace it with 'distortion' without changing the meaning of the conversation. This is simply due to the fact that the ear uses higher ordered harmonics to sense sound pressure and so if any extra are present, will cause the sound to seem louder than it really is.The author of this report compares their dynamics
This is a very common phenomena with SETs, which is why people often say they are 'dynamic'. But other distortion sources exist; consequently I'm always suspicious when I see this term bandied about. A slightly misaligned phono cartridge can have a similar effect as can improper mating of a compression driver to a horn (the taper being incorrect), cone breakups and so on.
Once the distortion sources are tamed, quite often along with having a more relaxed, transparent sound, the system won't seem as 'loud'.
I showed with the Steve's speakers at THE show years ago; they were easy to drive and sounded just fine.
If you do so you'll notice that there is some sort of metering to prevent you overloading the recorder. So you'll have to be careful to set the right level. If there is no metering for sound level then the system has an automatic gain control/compression scheme and won't make an honest recording.Next time when I'll go again to Bulgaria to Yanislav's house to listen to that system from the video I posted here (the one with the Altec 817) I will try to use not a phone to record the sound and image but something more professional with a good microphone.
I recognise I recorded that posted video here on a very poor quality phone (Samsung J5).
Because the amp might be quite musical. After all, its not the kind of amp that makes the sound, its the kind of distortion the amp makes and doesn't make which is important to the ear (IOW, that's the main difference we hear between various amps). If, as a designer, you understand that fact, that allows for a design to be musical regardless of its topology (or 'religion'...).Why would someone ever put big bore solid-state on high sensitivity horns? With a plasma tweeter, no less?
Again, amps and speakers are incapable of a musical preference. IOW you need the same characteristics to play Wagner or Stravinsky.I remember commenting favorably on this video before. What makes it a slightly different iteration? The system has the immediately and impact necessary for this kind of music. Perhaps not the last word in clarity which is vital for large scale complex symphonic music, but it is excellent for rock.
