Weiss MAN301 Music Server
edorr
May 11, 2010
3,146
3
36
Smyrna, GA
#21
Device is not something well suited for the WBF :)
I am using modded SlimDevices Transporter today (clocks, burson op-amps, power, etc.) with Behringer DEQ2496 in a digital loop.
Transporter is capable to "export" the digital stream before it enters the DAC to external processor and then take a correct stream to its DAC. In a digital loop, that Behringer processor well worth the money and the benefits of room corrections overshadow the drawback of having another component in the chain. Behringer is 96/24 and so is Transporter so this due works fine.
BTW, many devices I've seen (do not remember regarding Trinnov) are limited to 48KHz, or to 96KHz (in the best case). Even if they receive 192/24 on their inputs, the internal processing is limited to 48/24 to save CPU cycles. And I hate down-sampling, regardless what I am told - I do not need/won't hear.
The new Trinnov Amethyst will support 192/24 (existing processors will evenutally support it thorugh firmware upgrade). It will be released in December. It does DLNA streaming, DRC and comes with build in DACs and digital out. It does not have a build in music server. Price unknown. The WEISS looks interesting. You could run it digitally into a Trinnov processor and digital out into a high grade DAC. I already have the trinnov and DAC, but use CAPS server with Offramp 5 converter as a source. The WEISS would make a very nice alternative, but I would lose JRiver which I love.
Nov 17, 2011
75
Thanks, Amethyst might be an interesting product.
I personally don't want another box, and for me - correcting few specific frequencies in the low range will do the job. And all these features of Trinnov would be just wasted for me.
If it will be as good as Weiss MAN301 sound-wise, it will be a point to consider..
Why don't you work with the parametric EQ built into JRiver?
Also, there are tons of VST plugins..? Since you already have a computer source
edorr
May 11, 2010
3,146
3
36
Smyrna, GA
#24
If I had just 2 channel sources I would do just that and run EQ on the PC or Mac, or run a full blown PC based room correction system (Dirac for PC or acourate). However, I am also using the Trinnov for my Multi Channel application (I have a modded Oppo with 4 x S/PDIF out), that benefits a lot from the Trinnov correction. In fact, my Trinnov is 4 channel only so I just run R/L/C/LFE through it, and run the surround channels through an external DAC.
Dec 3, 2010
35
#25
Well, this is not that hard to do. Over the years I have worked in many studios, and the software platforms get better and better every year. If you are recording live music, Pro Tools is an industry standard (though I strongly recommend using non-Digidesign hardware and converters if you want good sound). Logic on the Mac Platform is still incredible, and it sounds a lot better that iTunes. It is production software, so not really meant for playing back audio files, but it sounds amazing. If you want to experiment, this is a good place to start. There are also many EQ plugins available for other audio production platforms ....
edorr
May 11, 2010
3,146
3
36
Smyrna, GA
#26
For two channel I agree. Making this work with multi channel on a PC/mac stictly in playback mode is not for the faint of heart though, if at all possible for a non professional user.
Dec 3, 2010
35
#27
True, though provided you are using a multi-channel interface, it is possible. The Weiss AFI1 together with multiple DACs would provide the flexibility. But of course, it is all very experimental and not well-suited for convenient playback of music files from a library.
Apr 5, 2012
655
1
Yes, the filter settings are generated automatically within REW based on the actual room measurement data, simply copy and paste the freq, gain and Q values over into fabfilter and done. I use it to pull down 2 problematic nodes between 30 and 70hz with 2 filters. The difference is so significant that I almost cannot enjoy systems where the bass response is not corrected for such as at shows or at friends places for example. I can detect even a slight linearity issue and find this very distracting.
Aug 11, 2012
56
1
6
#30
how sounds the Weiss MAN301 (used as transport only) when connected to Medea+ DAC VS Medea+ DAC connected to Jason CD transport ?
someone had chance to try such comparative tests ?
Best regards
