Visit to Detlof' place - Techdas, Kronos, you name it
bonzo75
24,738
16,082
4,490
London
Here I will share you my experiences from my "Wait, what's that - oh wow" tour.
I had planned this trip to Detlof’s to compare the Techdas and the Kronos, and was expecting to a see a slightly bigger than normal German Physiks speaker with a couple of Lamm M2.2s
However, when I reached his place, the first thing that struck me other than the size was the complexity of the speaker.
As you can see, it has 3 main drivers – the circular bass panel facing inwards to the other speaker is the midbass, and the ones on the outside are for the bass. Irrespective of how you position your speaker, they will point towards 3 different directions
As for the Lamm M2.2, it took a while for me to understand what was going on here even though I could see the below in person, so take your time while viewing a pic over the web.
On the bass (below 90) he uses the AVM monos, which go down to 1000 watts at 2ohms.
From 90 to just over 200 he uses Lamm M2.2, But What’s that, I said, pointing to the other Lamms. He said, Lamm M2.2. I said yes, but why do you have 4 blocks? He said they are bridged, so he has 4 monos, giving him over 700 watts at 2 ohms. “Oh, wow”, I said.
On the mids and up, he uses Atmasphere Ma2 MkII, which he loves and has had from his Soundlabs days. He initially owned panels and loved his array of three Quads.
Additionally, he has added Acapella plasma tweeters on top of the speaker, which are driven by 80w Jadis monos.
In case you have lost track by now, that is 10 monos. You see them with Stealth Cables on Synergistic Research platforms
Behind the main room sits his front end room, which had the MSB dac, fed through the Beast (a streamer), and the Techdas and Kronos. We started listening with digital, which he said was the Beast streaming through to the MSB. I was randomly picking up classical, operatic vocals, and the mids astounded me - probably the best I have heard. It is transparent like a stat and an MBL, but full bodied and dense, and those mid bass drivers and the mids omni driver position it in 3d between the speakers. Just more real. At this point, Detlof told me he was struggling to rip my CDs, but he could play the CDs directly through the Zanden CDP/dac combo.
What’s that? You have Zanden too? Oh cool”
He said yes, but the Zanden will play through the Kondo pre.
- Wait, What, you have Kondo too? Which Kondo”
= m1000mk2.
- “Oh wow”.
- Can we compare MSB through the Kondo and the Lamm to get a compare of the preamps?
= Yes
- “Oh wow”.
- Can we play both MSB and Zanden through the Kondo to compare the transports?
= Yes
- “oh wow”.
An hour later Detlof had managed to sort out the rips onto the NAS, so we could play it through the MSB. We played, as usual, digital of Bartoli, Bach cantatas, which have chorals, vocals, Oistrakh’s violin on digital, and Scheherazade.
Both of us agreed that on male and female vocals, there was not much to choose between the Kondo and the Lamm. On chorals, Kondo was more resolving, sounded cleaner and spotlit. Lamm sounded denser, with more in the mid bass, and sounded better on the Oistrakh due to the violin having more body. The Kondo had more space and air and dynamics. At this level, though, we are cherry picking differences in the spirit of audiophilia
We then compared the Zanden to the MSB using the CDs of the same files that we had ripped. We preferred the Beast + MSB combo on all fronts. The MSB had more bass, more dynamics, more body, and was resolving mass strings and complex music better. The Zanden had some prettiness in the highs and the mids. Detlof primarily listens to his MSB when he is not listening to vinyl.
With that, we moved to the Kronos. Now, the Kronos and Techdas as TTs cannot be compared in this set up, much as many of you would like to know the differences. They are just different set ups. The Kronos has an SME v12 and Goldfinger cart going through a Lamm LP1 signature. The Techdas had a SAT arm(which replaced the Graham elite) with a Kondo IO gold going through the Kondo.
Overall, the Techdas set up sounded more resolving and dynamic with greater bass, but Detlof did mention his Kronos was not sounding good today as he just had his SME arm modded. And that is the case with analog. Some days the stars do not align and it does not sound right.
Once when we were changing LPs, I rubbed a valve, a genie appeared, and there was also a highly tweaked Goldmund reference going into an ARC Ref 10 phono.
I then looked around and said, wait what’s that?
Oh that is the Zanden phono, 1200 mk3, said the genie.
Oh wow. And what’s that?
That is the Wavac phono.
Oh wow
Unfortunately, the ARC shut down on us. And it is not easy to play the zanden or the wavac phono in place of the Lamm or the Kondo.
So overall, how is the system?
The mids are fantastic as I said above. The bass and density and fullness is perfect. This is as good as a system can sound with the room restrictions. Yes, if one had a much bigger room, you would get a wider, and deeper soundstage, with bass booming down. Like the Apogee grands, the bass panels are tall and large and fire across their height, not just from a woofer section below.
The speaker comes with an external crossover, and Detlof uses a professional tool called DBX to map the crossovers. He can easily set and swap and adjust to the music played and the component being used. I asked him if he built this up gradually, one amp at a time. No, he always wanted to triamp, so he went all in with a big bang and set the amps in 3 months. Of course, triamping is for younger people with less energy, so he quadramped.
Detlof is the perfect host. At over 80, he is full of energy, and since his preamps do not have a volume control, he keeps crossing over from the seat past the system to the other room and back. He leaps across all those wires, bends down to fix things, tries some DIY stuff, is trying to make power cables for his own challenge. After dinner the audiophile curse hit and there was a blackout. But after putting the generator on, he did the trouble shooting of all the NAS issues, got the Beast reconfigured, and we started playing again.
Detlof loves playing with his tweaks, so his components are all on Synergistic Research isolation bases, Walker audio feet, and Entreqed, with Stealth cables looking like Pythons carefully winding through them. He has damping on all his components including the laptop. He also has a Tripoint on one of his phonos. He knows some of his tweaks work less or not at all as compared to others, but for him, and rightly so, it is all about the fun of playing.
There is not much you can do to this system. It is immensely enjoyable especially given that Detlof and I share similar music tastes – he loves his strings, opera, piano. The piano on Rubinstein Beethoven Emperor was fantastic.
Great story.I bet that visit was terrific. Thanks for sharing and thanks to Detloff for having opened his magnificent set up to you
Unfortunately, these audiophile journeys end with regrets - the regrets of what I did not get to hear. I still rue the fact that despite all that I learned at ddk's I did not get to hear the Micro Seiki 5000. This weekend, I did not get to compare all the phonos in Aladdin's cave.
Also a special shout to Ralph. The mids with the Atmasphere were sounding excellent and Detlof was full of praise for Ralph and his customer service.
any more pix to share, Ked?
Nice read Ked and somewhat reassuring to learn that there are audiophiles out there with (even) more components than me.
As regards the vinyl you listened to though the Kondo M1000 mk ii: does Detloff use the Kondo step-up?
We heard it through the built in Kondo phono.
How does Detloff integrate the Acapella plasma tweeter with the tweeter in his German Physiks
What a wonderful report, bonzo! Thank you!
I really liked the small German Physiks in Irvine.
I looked at their website and wondered what their big system might sound like.
So (and maybe it will take a little while to process what you just heard so feel free to demur for now) where does that leave your thinking and preference ordering for female vocals and male vocals among ML electrostatic, Apogee ribbon, Analysis Audio ribbon, horns and, now, the German Physiks driver?
What did you make of the plasma tweeters on top? Is there an attenuator for each tweeter?
Super stuff and very well written, as usual, my dear friend! Most insightful and inspiring, to say the least.
As I said, when I grow up, I want to be like him.....I hope my passion for music and equipment never dies!
Cheers
Sujay
Ked where was the Kronos hidden
On the other hand you've seen and experienced the extremes of high end hobby from simple SET horn installations to the other side of the seesaw with Apogee Grands and Detlof's German Physics!
david
Hi we are talking different levels of scale Ron.
I think stats are excellent on a VFM perspective. What you get from Acoustats and Quads, is impossible to beat until you reach a certain level. I have yet to hear a smaller Apogee I liked, and each restore sounds different. The Analysis Omegas sound better to me, when modded, than corresponding Apogees. But then you get the Full ranges, which restored by Henk sounded delightful and well over any stat or Analysis I heard, and costing, actually, the price of a Summit. And I have yet to hear well-restored Divas. Then is the jump to the big league of the Grands, and these German Physiks retail at more than twice the cost of the grands, though their street price will be closer to the Grands. And there is a whole raft of horns in between, each one sounds different, so I really cannot treat a Horn as a generic category.
For your transparent tastes of stats and MBLs, the Acapella is similar. My taste, as you know, also requires fullness and density, which I find in Apogees, and Detlof's GP had it in spades. You should know that Henk's Apogees were driven by much lower level of electronics compared to what I heard today - difference being roughly the cost of the GP itself. That said, I think the GP are capable of better mids. For a room the size of Detlof's it is a no-brainer. Apogee Grands just won't do well there. In a bigger room too, the mids between the speakers due to the way those midbass drivers center it in between, will probably be better. But then the Grands will be faster and slammier and I love their integration.
The WE 16A will still remain a special speaker, because what it can do, nothing else can.
I really don't know the answer to how Detlof integrates the Plasma tweeter, but it does not come into play much. He said it does during jazz.
