Shop trick for soft domes -- take a piece of tape, carefully work it into the dent so it adheres well to the now convex surface of the dented dome, then slowly pull it out/off. The dome comes out with it.
Tim
Tim
Tim
I will remember that one...
Before we talk about that, this speaker has pretty bad directivity. This is its far off-axis response (what you would get from side wall reflections):
That trough in the 1.2 Khz region shows that there is too much of a gap between the woofer and tweeter. The former becomes too directional before the latter picks up the load, causing that dip. This means that you likely need to absorb those side reflections as otherwise, you are going to have a trough in the area of most sensitivity for the ear. That would then take away some sense of spaciousness.
Back to the tweeter, this is the speaker's direct response:
I think Jeff is talking about the resonance that causes its level to peak at 20 Khz.
Tim
Thanks Steve. Do a test for me. Walk up the speakers while playing something, get your ear down to their level and walk around in a half circle. See if anything tonally changes. Keep your (one) ear parallel to the speaker as you do that.
Steve-According to Harman, you traded one bad speaker (the Martin Logans) for another bad speaker! Unless I looked at that graph wrong yesterday that Amir posted, your speakers don't have much bass below 70 Hz and yet you say the bass is "phenomenal." I don't know where the truth lays Steve and I'm not picking on you. I really don't want to believe that if the W/P 8s really sound the like the measurements indicate they should that the entire run of W/P speakers fooled so many thousands of listeners into believing they were hearing really accurate reproduction. And again, I have never heard any of the W/P iterations and I have no idea what they sound like and nor do I pretend to.
Ha ha, no problem. I have been at this audio game for a long time. I've owned many, many different speaker brands. None of them has had the incredible bass that the WP's have. The frequency response of the WP8's is from 21Hz - 22.5kHz +0/ -3db and sounds it. I've had subwoofers before that don't come close to the bass response these speaker have. My friend with his Summits and sub comments quite regularly that he wished his bass sounded as good as these speakers do.
With four 14" subs each driven by their own 1800 watt amp, I know the difference between bass and midbass. I looked at the graphs you posted of the Thiel CS2.4 and it looks like it is fairly flat to around 35 Hz and then nosedives.
Jeff-No, no one has posted measurements of the speakers I own so I'm not in this for any personal reason with an axe to grind. I'm simply asking some questions. Do you agree that the Thiels drop like a rock at around 35 Hz?
