More stuff to ponder which, again, is the basis of MIT's claims:
The question arises, how are these phase angles measured? Recall from the phasor form of Ohm’s law the phase difference of the voltage and current is equal to the phase angle of the impedance: ?z = ?v - ?i. This is an extremely important result. The phase angle of the impedance is a quantity that can be measured directly using an impedance analyzer. Thus, insight can be gained about the relative phase angle of the voltage and current in an audio cable simply by looking at its impedance. [...] The power factor is defined as PF = cos (?v-?i) However, the power factor is usually given as PF = cos (?) where ?, the phase difference between the voltage and current, is known as the power factor angle. Since we can measure the impedance phase angle of cable, we can calculate the power factor of audio cable by simply taking the cosine of our measurement. We can then use the power factor as a tool to characterize how efficiently an audio cable is functioning as a coupling network.
In the patent quoted before, he then uses an impedance analyzer and claims to find capacitive phase angles ~-87 to ~-85 degrees (or ~-3 to -5 off optimal) at various frequencies in the cable under test, which he considers significant...
