Is it not as simple as more total resistance?
Certainly possible. Those figures aren't at my fingertips.
Variations in volume among different cables is quite common, sometimes even extreme. It does make me wonder then what's going on when I have to increase the volume on the GAT some 20 steps.
Perhaps analagous, Wilson almost always shows with VTL but many posters here and elsewhere don't find that pairing as appealing as different ones.
I got the chance to audition this speaker driven by my Spectral system last week, the same system used during Magico, Rockport, MatrinLogan and other speaker auditions in the past; all I am going to say is, what a truly stressful experience that was - it had me dashing out mid-audition, scrambling for chocolate for relief; I found nothing accurate about this speaker, clearly not my cup of tea. Sorry folks.
Perhaps it is the electronics, though current is not an issue with the Spectrals - 90A peak - nor is impedance down to 1ohm; perhaps the MIT cables not being a match for Wilson??? If it is the amps, it would be the first speaker I have heard that the DMA-360 S2s cannot drive. But what I heard was overblown, slow and overly warm bass, slow midrange, what appeared to be a bit of echo in order to give the impression of depth, images not well defined and a bit larger than life, and absolutely nothing true with respect to timbre up and down the spectrum. The room appeared to be well treated. I took the following picture of this dreadful experience.
In regards to accuracy, I'm sure it's not a very accurate speaker. One former magazine reviewer (who I'm not going to name) recently said:
"The current issue of Stereophile has a review of the Wilson Alexia. In room measurement, 7 dB from 300 Hz up to 2kHz (300 Hz down relatively). Middle C's fundamental 7 dB depressed relative to its 8th harmonic? Pianists with left hand enervated? Cellists out for a Starbuck's break?"
ack,
The Magicos spoiled you for good...
My impression of the Alexias matches yours. It's an OK $10k speaker, not $48k.
alexandre
Is that one of the listening rooms at Innovative AV in NYC?
If so, that might also explain things.
Would had helped if they were not going for a sensationalist narrative, because in reality at JA's room it was 4dB down from 300 Hz to 500Hz where flat including then to 1.5KHz, and then the peak trait that started flat from 1.5KHz and peaked at 2KHz with +4dB; to see how much is the room look at other speaker reviews JA has done.In regards to accuracy, I'm sure it's not a very accurate speaker. One former magazine reviewer (who I'm not going to name) recently said:
That's what I assumed and that's where I heard the combo in NYC. The dealer warned that the room was not ideal in many respects and that the speaker would certainly sound better in homes. For that reason I don't think he played anything that would draw attention to bass nodes. I heard piano + sax and it sounded very nice.
To get a feel for its response in a room, ideally would need several different reviews (different speakers same room) and critically other reviewer's room (for that same speaker model) measurements and see if traits can then be identified along with the quasi-anechoic or more ideally the NRC measurements done in Canada.
That said some speakers will measure better at a specific distance rather than 1m driver measurement due to their design.
Just my take anyway.
Cheers
Orb
