Listening test sensitivity is the issue, I thought that was clear. .
No, Ethan, that is a tautology. It may be true, but the logic isn't, nor is the data ("nobody"? Really??)
And it fails to address the question at hand, which is why measurable differences in frequency response in the audio band are not necessarily detected in listening tests.
The blue one sounds better. Anyone can see that.
Your opinion has no effect on either physics or psychoacoustics. By the way, who were you really quoting there, anyhow, and in what context? Would you prefer to be a bit more careful in your quoting in the future, say so as to not avoid context?
I still read Ethan's post as referring to listening tests - "nobody can hear a difference" - and that's still where I see the emphasis of this entire discussion, with a (admittedly necessary) digression into measurements.
But that's my point. If two wires both measure flat enough that nobody can hear a change in response then anecdotal reports of the wires sounding different are incorrect and due to faulty perception.
--Ethan
Really?? to me, "hear" means listening. I don't how you measure "hear" outside of listening tests.
for me, i would want to see a few more measurments before i closed the book.
Since that's not what I said, you shouldn't start running with it. What you say is true, clipping will create greater loudness for the same energy than an undistorted signal, unless the undistorted signal is something like equal-energy-per-critical-band, which would be weird, but would maximize loudness.I'm well aware of the trick of introducing a bit of clipping in order to convey a sense of loudness - any kid with a tape recorder knows that! But is it hi fi?
Now you're putting more words in my mouth. Where did I say "should"? Hint, I didn't.It sounds as though you are coming from the angle that distortion should be introduced deliberately to enhance the apparent dynamic range. And this distortion just happens to be the kind produced by vinyl and tubes. Wouldn't it be more controllable to use a zero distortion amplifier (or as close as we can achieve) and apply DSP to the signal - if we really must?
I can see that if we have no choice but to use sources and amplifiers with limited power and/or inherent distortion, then we might want to tailor that distortion to give us this loudness effect. They do it with tablet and mobile phone speakers to make them seem more dynamic. But my experience with low distortion systems, big speakers and the right recordings (of course) is that clean playback can be breathtaking. It would be a shame to mess it up with added scuzz.
J_J,
No one can quote everything relevant in such threads. Although I do not expect people to read it all, I hope that people have to have read al less the last pages and know the usual positions of usual posters. This to say that I had raised the issue before a few posts back and had asked another poster to clarify what he was including in when he referred to "electrical performance" and how he measured it, but got no answer.
The second aspect is that unless you specify what type of blind test you are exactly referring, your question is vague, independently of the need of positive or negative tests.
I end copying and modifying your sentence "Would you prefer to be a bit more careful in your answers in future, preferably reading the poster last posts before replying?"![]()
Measurements alone are certainly not going to convince me, especially not a single type of measurement (e.g.freq response).
1) at least you could maintain the local context.
2) actually, the only question one needs to answer about a DBT is "is it done right". No, it does not matter which kind, as long as its done right and has proper controls. There's nothing vague there, although it does take understanding of tests to know what "done right" amounts to.
3) That's not an argument, that's mere repetition! http://www.youtube.com/watch?v=kQFKtI6gn9Y
(...) If I find a cable in which the least mean square error is at or below -120dB peak output, for any signal in the DC to 50kHz range, would you agree that was transparent under any normal listening scenario (that isn't itself broken)?
I said "It sounds as though you are coming from the angle that distortion should be introduced deliberately..." thus inviting you to correct my impression if wrong. I still don't know whether it is wrong or not.Now you're putting more words in my mouth. Where did I say "should"? Hint, I didn't.
Aha! So you are advocating added distortion to increase apparent dynamic range... I think. Couldn't you simply use a dynamic range expander to do it with minimum distortion?You're showing the same kind of contempt I have seen in a lot of other people who don't actually understand who perception works.
You are also utterly missing the difference between ACCURACY and PREFERENCE.
What do you say to someone who personally prefers the exaggerated dynamic range.
As to using "DSP", ok, what DSP would you be thinking of?
Sorry the clipping thing came from an earlier post of yours where you talked about "harmonic splatter that happens when the system gets to peak levels" and I wasn't sure whether you thought it was a good thing or not. I still don't.Note: I am referring to vinyl, and clipping does not enter into this discussion, clipping is far, far too "hard" a distortion, just so that's clear. Tape overdrive is, to some extent, more like it, except tape overdrive also erases high frequencies, and creates a problem when the bandwidth expansion actually reduces the bandwidth.
j_j said:Let us hypothesize for a minute a system that exhibits .1% distortion (not counting noise) at -20dB, 1% at -10dB, and 10% at 0dB relative to its overload point.
Now, what will happen with the harmonic splatter that happens when the system gets near peak levels?
I don't think measurements, any kind of measurements, are going to convince the folks who believe in high-end wire. I suspect that even if you conducted blind listening on them personally, and they failed to consistently ID their favorite high-end cable vs. Radio Shack wire, they'd believe that something in the blind listening was wrong and that their sighted conclusions are still right. That is the way it has always been. Nothing has changed. The subject has just come around again. Until next time....
Tim
I'm reporting a testable, verifiable result. I am not advocating anything.Aha! So you are advocating added distortion to increase apparent dynamic range... I think. Couldn't you simply use a dynamic range expander to do it with minimum distortion?
I didn't realise that asking a question, then in the absence of an answer, attempting to develop a working hypothesis was personalising the issue! I'm just interested in what you think is a good thing, or a bad thing, or a useful thing.I'm reporting a testable, verifiable result. I am not advocating anything.
Is there some reason you must personalize the issue?
OK, let's call it 'soft clipping', or 'saturation' or 'approaching overload'. I think you know what I mean!Clipping is not generally good. Digital clipping is particularly and egregiously bad. The system I described is not in any fashion clipping so I still have no idea why you keep harping on this issue.
As to why you can't use a dynamic range expander... Let's think about it. If distortion around peaks (still not clipping) doubles the apparent loudness, now how much more power (in ratio terms) would be required for the same sensation, assuming linear behavior?
Can you tell me? If you can, you already knew the answer.
Maybe, maybe not. The problem (as has been mentioned repeatedly) is that really are virtually no well-designed and well-conducted blind tests of cables, nor (unfortunately) are there likely to be. The manufacturers have little incentive, and the naysayers probably don't have the resources.
Remember, for a test like this to be meaningful, you also have to show that the listeners correctly identify cables known to have potentially audible (even to objectivists) differences.
