By the way, can someone splain to me what coupling is good for, and also de-coupling,
and isolation as well?
Where and when one becomes critical?
And is there any weight to stabilization? I mean is weight help to stabilize your speakers?
...Of course it does.
Thank you.
A few points to get us going. First of all, vibration in anything but the driver cone or equivalent is bad, because you can guarantee that that vibration of the flat surfaces of the speaker or frame is not going to be beneficial to the sound. If you're very lucky they may harmonise with the sound, but you would have to be fortunate.
Now I mentioned in an earlier post that the speaker box is going to be shaken by the cone doing its thing; it has to because of old Newton's laws, for every action there is a reaction and all that sort of thing. The manufacturer may help if he's really nice by putting viscoelastic materials in the construction, the CLD, constrained layer damping I just mentioned. Typically in the sides, two layers of hard material with viscoelastic inbetween: the inner surface wants to rattle, so it pushes and pulls on the viscoelastic which works exactly like the shockers on the car, turns the energy into heat. So, inner surface rattles, next layer damps by getting warm, and the outside hopefully has minimal rattling.
Isolation works on the vain hope that if you don't have the vibrating surfaces or edges touching anything then the rattling will go away all by itself. Well, unfortunately there is no way to have a speaker not touching anything unless you have some magic anti-gravity device available, because it has to remain in place in the room. Even if you use ropes suspending the speaker in midair, the ropes have to hang from somewhere, and guess what: the vibrations of the speaker go up the rope and pull the mounting bolts in the ceiling up and down: your ceiling area becomes a panel speaker. Of course, if you want to go extremes, you could punch a hole in the ceiling and roof, build a gantry structure on the ground in the garden, and dangle a rope down through the hole. You're getting pretty close to isolation now!
So isolation in a typical situation is a myth: the speaker has to touch something to stop from falling down to the centre of the earth, and whatever it touches will vibrate, and on it goes. If you try putting it on a very rubbery thing of some sort that will stop what's underneath from rattling too much but what will happen then is the rubbery thing combined with the speaker will happily bounce ferociously and heat up the air around the speaker by its movement: this dissipates the energy but doesn't do much for the sound.
There is a whole science about handling vibration, it becomes quite messy and mathematical, companies make a lot of money trying to sort it out for customers, and a key technique is to turn the rattling into heat. Sometimes a solution may be found by a type of isolation, but the downside is that the thing that is moving could have little means to get rid of the vibrational energy and the device may end up shaking itself to bits.
Weight is good because it slows down the rate of vibration, the speaker box, not the drivers, goes from being a tweeter to a woofer! It's still vibrating, but the frequency is now nice and low, far less irritating and the energy has a better chance of transferring to what the box is touching. Again, there is a whole complicated science about all this.
And so endeth the lesson for the day ...
Frank
