No different than modifying any other audio components, which endless number of people do to their amps, cd players, speakers etc. No different than buying a computer and upgrading the RAM, swapping the cpu out to make it more powerful. There are a lot of companies like ModWright who modify audio components to sound better and DYI's who tweak audio systems. We are not talking about nervous tweakers, we are talking about someone who is comfortable working on electronics. Yes I do agree that Devialet themselves would be very reluctant to supply the module to do a swap even if it was possible, it would be detrimental to their business and profit levels. There are many audio equipment which are many times more expensive than the devialet, which I have had in my system, so in that way the devialet is just another audio equipment, not rocket science. A lot of people like me are not afraid to modify our equipment given the possibility, otherwise there would not be DIY companies or forums catering to such people. I don't know why you insist on putting Devialet in such a high pedestal, when there are 100's of audio components 10 times more expensive than Devialet.
gorkitek, please be assured I do not want to really go on this topic anymore, there are a lot of products on the market in audio with power factor corrected power supply including most power conditioners, my Pioneer Elite AV receiver definitely has more dsp inside or for that matter any AV receiver and so does any DAC in a reasonable price level.
What Devialet has done different is the amp module the ADH and surface mounted every single component to make it more compact and shorter signal path etc etc, the circuit board looks no different than say a normal computer which hardly has no wires.
Maybe you have never seen the demonstration of devialet taking off the Digital module amp and running it in class A, search the tube. Like the wireless card which when first released the user could install it in 10 mins and have also done so, as it clips on to a slot and easy to do.
I don't know what the argument here is all about as the D amplifier module just clips on to a slot on the main mother board, have you even looked at the interior pictures. As I have indicated that the difference in power is just due to a different D amplifier module board, which could be easily swapped if we could get is separately, which likely wont happen, It was just an IDEA and which is easily POSSIBLE.
I don't know what's the big fuss here................
I have indeed with my own D-Premier, a couple of years ago. However, this misses the point, the performance of the Class A amp is actually very different with the ADH (digital) module removed - for example, the output impedance rises dramatically and the linearity declines with reactive loads. The design of the ADH system is very subtle, particularly the multi-phase drive and the elimination of any low pass filters but the overall performance is identical up to any maximum power rating which will be set by the available p-p voltage swing for any particular load with the D module in place.
You can of course set this swing yourself and so I am not sure why you would want to change the digital module.
G
I have taken delivery of a brand new pair of D Premiers this weekend. Superb product and outperforms my outgoing Audio Research reference pre and power amp! (to my ears anyways!)
I read on the website help section that the preferred connection between master and slave is RCA to AES/EBU. Currently I am using RCA to RCA but would like to implement the optimal solution. I have two questions:
Is it possible to configure the AES/EBU on the master unit as an output? It does not appear so on the online Configurator. I have no current need for the AES/EBU input so would prefer for the connection between master and slave units to be AES/EBU on both ends? Especially as the connection between master and slave will be long.
Assuming that answer above is negative then the suggested preferred option is RCA to AES/EBU. My question then is which type of cable should i have made up?
a) would this be an AES cable with an RCA - ie AES uses two twisted cores (hot plus cold) in a screen (ground); or
b) a coax cable with an XLR? ie one core ((hot) inside a screen, where the screen is the ground and cold conductor at the same time).
Your shedding light on the above would be greatly appreciated!
Oh it was just a wild thought, as I thought the cost of that small digital board cannot be much, as all it would have is a few extra output stages for more power. So if I could just have more power for almost the same price as I paid for the 170 it would be stellar and maybe even sell my module to someone with a 110, which likely wont happen as the power supply in the 110 and a few other things are different. I am an engineer so my brains are always ticking, I am always thinking of ways how to achieve maximum gain without spending maximum money. By the way I am not really a geeky engineer, given the fact that I am in Sales, but my mind always wanders, LOL!!
Anyways eagerly waiting for my 170, hopefully this week.......the damn shipment should come in soon, but I have not heard a peep from the dealer yet.
One reason I went for the 170 is the green aspect of the technology and to simplify my setup as much as possible, living in a condo. I have changed 4 amps in the last 1.5 years plus other audio stuff, its just a crazy hobby for me, as I like to try new stuff![]()
I agree that the new straight lines of the 170 is nicer looking than the 240, it looks cleaner. I think lets wait for the review coming out this month on the 170 in one of the audio magazine, where they compare it to the older d-premier. Devialet themselves have said the board, power supply and the processor is better than the older d-premier. If you really can pick up the d-premier for the same price, for me it would be a 50/50 option as we wont know how much better the new refinements are, as they had around more than 3 years to refine the design, or tweak it since the first launh of the d-premier.
I have the opportunity to pick up a demo d-premiere for a little more than the price of a 170. I'm really interested in the USB and ethernet in the 170 so I would likely upgrade the d-premiere when it becomes available. Not that it's a deal breaker but I do like the look of the 170 more than the d-premiere.
Does anyone have an opinion on which one I should get?
Just to clarify, what Devialet (Thierry, who works for them) has said is this:
"Now, the differences between the D-Premier and the D240 are mainly the inputs and the new DSP. If you don't need the new inputs, the D-Premier might just be the perfect answer to your needs! Even if we have tweaked here and there the electronics, I am ready to bet that very few people can make the difference between a D-Premier and a D240. Why? Because the D-Premier is already the ultimate music reproduction tool!
The D110 doesn't sound better than the D-Premier. It has the same sound signature. It has the same ADH stage. On the other hand it has been stripped down to answer the needs of a particular customer base who don't need the bells and whistles of a D-Premier or a D240, will never need to build a multi amp system and just need 110W of power. Totally different products for different needs."
This is refreshing honesty from a manufacturer when many would say "our new product is better than our old one".
Devialet are effectively saying "The D-Premier and the 240 sound the same. If you want the same sound signature with less power and fewer facilities you now have some cheaper options in the 110 and the 170."
Just curios which Audio Research Reference did the Devialet replace? Thanks
I do not agree as I have read that Devialet had some comments on their website saying the new products were better and then took it off from the website, especially not to offend existing d-premier owners. I am not saying that the original d-premier is bad in any respect, but to simply say that the the newer products are not better is BS. In every industry i.e. audio, cars etc. the manufacturer brings out a new model or different revision, making it better. Are you telling me a 2014 Porsche 911 is equal to a 2010 911 model?? If that may be the case simply technology would not advance. Again I am not saying the original d-premier is bad at all, but life moves on and so does Devialet as a company who's business practices cannot be different than any other company, in order to survive. I don't care what PR hash they try to give, it is extremely hard to swallow that the 240 will sound exactly as the d-premier, given the power supply, board and DSP are different.
I do not think the management team or the engineering team at Devialet would be sitting there thinking, ok we made a stellar product when we launched the d-premier in 2010, now it is 2013 and we are launching 3 new products, lets keep everything the same but offer few options and make no changes to the exiting technology.
Where are you from?Bad news, I called the distributor as they know more than the dealers about stock, and the distributor said that there is no stock for the 170 earliest shipment will end of July and the next end of August. Damn so disappointing!!
No product is perfect, the world would be boring then. But working towards perfection is a continuous improvement and that's why we have new models with any products in life, it doesn't only have to be cars or audio!Well, there are three solutions.
1 Take it up with Devialet and dispute what they are saying in terms of sound quality
No one is disputing what they are saying, I have read that they have changed some comments on their website - are you disputing the fact that they have changed wordings?
2 Buy a D-Premier and a 240 and get statistically reliable differences using double blind testing
When you have reviewers and dealers and future buyers, I am sure we will hear the different opinions once the new models trickle in
3 Believe what you want to believe
Everyone is entitled to their own belief, otherwise we wouldn't have different opinions or views in life!
Yes, I suspect they have improved the engineering of the boards as one would expect after three years' production management experience. Improved the sound discernibly - doubtful.
How do you know, have you heard them both, there are other forums where where one person has confirmed that the 170 sounds better than the d-premier and the dealer he was listening at also concurred the same. Do I believe in everything I read online, absolutely not - all I am doing is trying to find out as much info as possible about the new products as there isn't any formal reviews yet.
And as for use analogies, the Porsche example (which Devialet carelessly used themselves) is hardly appropriate as it is seeking to solve much more complex problems and still getting nowhere close to perfection.
