Antipodes Owners - Systems - Whats Best at Your House
kennyb123
858
806
1,155
Kirkland, WA
Also, would you be good enough to provide the link for the web browser interface you mentioned earlier for Squeezebox?
You may have to do some digging so search for “material interference lms”
KrellFan1
152
105
45
Phoenix, AZ
For the Sonic Transporter, it is possible that you will need to install the Qobuz plugin, I'm not sure if they come configured with the plugin already installed.
For the installation and launch of the web interface, see below:
Go to Apps, install Squeezebox Server from Software Manager, then click on Squeeze Box Server.
At the top right corner of Squeeze Box Server. select Choose Player drop-down and select your player, the K22 should be available here
Perfect, and thank you, Mark! I shall try tonight or tomorrow for sure and report back on my experience! SB easy enough to go back at any time, and yep, I know everything easier and better with the K41! Soon! Promise!
gentcan
66
18
13
51
I just got my Oladra upgraded to MK2 today but it’s strange that there’s a new ground screw added near the power IEC socket so I couldn’t plug my PC into the socket. Is there any way to do that? Please see attached picture and advise. Thanks
