Nope. It is a highly-specified quad twisted-pair cable with great consistency and applicability. Look up AES72-2019.
Thanks! The same issue of supporting balanced line properly is still an issue though. Mogami, FWIW, has been offering quad cables for decades on now. I've found they really don't make any difference if the equipment driving and receiving the signal both are AES48 compliant and are also capable of at least -4dBm operation.
Yes. See above. In high end audio, we expect the cable to do the heavy lifting WRT to sound quality.
In broadcast and the recording industries, traditionally its been adherence to the standards that has forced cables to have good sound quality. IOW the equipment on either end of the cable does the heavy lifting, not the cable. This is why so many audio engineers will tell you cables don't make a difference- if they are in recording or broadcast, they don't!
Why would anyone selling the cable with huge markups want people to go to an almost free cable?
It is like Jimney Cricket cautioning Pinocchio about letting his conscious being his guide.
Yup! I have a Sisyphean task. But if you think about Sisyphus, eventually that rock is worn down to a pebble. It just takes time.
But to answer your question, they would not, which speaks directly to the title of this thread. But so much of high end audio balanced line equipment isn't designed to prevent interconnect cable interaction (isn't compliant with balanced line standards), so 'high end audio' cable manufacturers can freely make expensive cables that do indeed make a different with that equipment, which IME is most balanced line gear made in 'high end'. Hence the on-going debate about whether balanced is better or not. I've found that if you do it right there's no going back.
What makes you think a cable that merely complies with standards is automatically neutral, free of any sonic character, and incapable of imposing its own signature?
If you believe standards like AES-48 guarantee ultimate neutrality and erase the sonic differences between conductor or insulation materials, you’re mistaken. And if you don’t hear otherwise, you probably need better equipment—or sharper focus when listening.
Standards don’t guarantee anything. That’s the plain truth.
Its not the
cable that is the big deal. Its the
equipment driving it and receiving the signal. That is what AES48 is all about. If you think I've not auditioned the differences or lack of them, using compliant
and non-compliant equipment while
also being the oldest supporter of balanced line connections in high end audio, you'd be mistaken.
Standards aren't much use if no-one pays attention to them. But try and see how well a USB cable that is non-compliant works for passing digital audio and you might understand the problem.
this is another version of the language is corrupt and virtually meaningless. Neutral? Accurate? Musical? Organic? Uncolored? etc. what these words mean is totally dependent on who is using them. Cables all act as filters and so different filters do different things.
The fact that every show there are more cable suppliers reinforces the notion that cables are not the same and neutral is what they all claim to be.
This chicken or the egg moment is totally based on how do you voice anything and by voicing it what did you use to do so in conjunction with the product you are building.
Yes this is a conundrum rapped in a riddle enclosed in a puzzle of meaningless words but what the heck would we argue over without this
You might wonder how RCA Living Stereo LPs sounded as good as they did. Or Mercury Living Presence, EMI or early Decca (London). In some cases there was over 100 feet of (what would be considered by 'high end audio' standards as really terrible) microphone cable before the signal arrived at the input of the tape machine. Yes,
all cables act as filters so
if you apply filter theory to a cable you
then design a system that prevents cable colorations in the audio range. Besides AES48, one of the techniques is low impedance operation. In the old days of tubes line level standard was 600 Ohms. For microphones (like my Neumann U67s) the standard might be only 150 Ohms.
Most modern 'high end audio' preamps will fall flat on their faces driving such loads! It requires that the line stage be a small power amp in its own right.
I don't know if the standards for balanced operation are unknown in high end audio or simply ignored- its likely both. But when we started doing balanced line decades ago, the assumption was that if there was an XLR output, it had better be able to drive 600 Ohms without any problems so that's what we did. If you want to talk about 'high end audio manufacturer honesty and transparency' this cable thing has got a
lot of deception IMO/IME and for far too long (I knew Robert Fulton, the guy who more than anyone else founded the high end audio cable industry back in the 1970s). But the hoops you have to jump through to get balanced right might be more than many manufacturers would want to face.
