How do you not connect pin 3? Do you break pin 3 off the connector?
Heh. Connect no wire to it.
Hmmm. How do you do that? The cable is already made with the XLR. I must be missing something obvious!Heh. Connect no wire to it.
Tim explained this but to expand.Hmmm. How do you do that? The cable is already made with the XLR. I must be missing something obvious!
Ah. So you need to search out for those XLR cables with floating pin 3. I guess if your system has all True Balanced in diff. mode components, then no need to worry about floating pin 3. It's only when using a psuedo balanced component connected to a true balanced component?Tim explained this but to expand.
Each end of an XLR connector has 3 pins. In a "normal" cable there would be three wires inside that are connected (typically soldered) to each of the three pins at each end. If the manufacturer doesn't want to use pin 3 then the cable would only have two wires on the inside that are connected to pins 1 and 2. When you plug this cable into your gear pin 3 would simply be "floating".
Nice choice Ron! I look forward to seeing how this cleans up your beautiful set-up.I have a bit of a rat's nest of power cables from the five digital devices:
streamer power supply
reclocker
EtherRegen
DAC
CD player
Plus, these low current devices greedily used up five of my special electrical system duplex outlets.
So I figured I would get an extension box and plug it into one of my special electrical system duplex outlets, and plug these low current digital devices into the extension box. As long as I was getting an extension box I figured I would get an isolation transformer version and keep the digital cooties away from my analog stuff.
So I ordered a Torus Tot Max. This will free up four of the fancy duplex outlets.
Try Stack Audio eq’s and speaker footers. Money back guarantee. I’ve replaced isoacustics with these. Very impressed. Start with the dacI am a tweak skeptic. To me it is all audiophile nervosa until I hear a net sonic improvement.
If a clock is using a crystal oscillator (I have no idea if it is, but that used to be the standard frequency reference in radio land) I can't imagine it's too susceptible to minute vibration.
But rather than debate it, this is an easy thing to test: do you hear anything untoward in the music from your clock when your woofer towers are moving in anger?
I am really liking the Opus 1!
No, you're making an assumption. I am not demonstrating the system. Don't you know by now that you cannot understand the sound of an unfamiliar analog recording in an unfamiliar system in an unfamiliar room through a digital YouTube video?Any video with proper music? Just the fact that you think such random noise clips can be used to demonstrate a system makes me go the same temperature as a tube amp struggling to drive your speakers
It's background music – – like elevator music – – just to have some accompaniment to the video. Next time I'll make a video just for you with the musical accompaniment being only my mellifluous voice.
Oh, let me record another one, much louder this time, straightaway!This video makes me want to jump out of am elevator.
As elevators only open at floor levels it's probably not worth itOh, let me record another one, much louder this time, straightaway!
I hear a lot of things wrong with the sound...even if it is not "proper" music that probably has nothing to do with the TT/arm/cart/phonostage. It might have something to do with the amps but sounds more like room issues. The mics are usually a bit exaggerating the room effects on these phone recordings, so there is that. I am still waiting though to hear a really good recording from you with the Clarisys setup. I thought a few of the ones you did with Pendragons were good, so I know it is possible in that room at least with those speakers/amps.I am really liking the Opus 1!
FixtI hear a lot of things wrong with thesound...noise
It is not any music. Just noiseThis is not background or elevator music Ron.
Fixt
I think the problem is about room and speaker position. I feel the amp clip but the main problem is not amplifier. Ron can change speaker position to see what will happen. It is better to play a good record like roger waters “amused to death” because it’s low compression.I hear a lot of things wrong with the sound...even if it is not "proper" music that probably has nothing to do with the TT/arm/cart/phonostage. It might have something to do with the amps but sounds more like room issues. The mics are usually a bit exaggerating the room effects on these phone recordings, so there is that. I am still waiting though to hear a really good recording from you with the Clarisys setup. I thought a few of the ones you did with Pendragons were good, so I know it is possible in that room at least with those speakers/amps.
