Which “few”? In horns?I’ve only heard a few beryllium tweeters, and they sounded unpleasant.
I don’t want to buy a system so that people follow my thread. You have the wrong objective
I can’t match your experience listening to other’s systems. Have you heard a horn like mine breaking up?
What mods are you doing to the Altecs ..?
Your Q3 has a beryllium tweeter.I’ve only heard a few beryllium tweeters, and they sounded unpleasant.
Which other beryllium tweeters have you heard that sounded unpleasant?
As you have read all my posts very keenly for many years, am sure you know
If beryllium isn't done right, I agree they can be unpleasant. WRT breakups, its the sort of thing that you realize in comparison. I didn't realize the aluminum diaphragms were breaking up either. They don't have to play loudly to break up.I’ve only heard a few beryllium tweeters, and they sounded unpleasant. I’ve never heard my compression driver break up.
I found my Altecs had considerable resonance from the cast horns so I damped them using roofing cement (this was back in the 1970s). It made a considerable improvement! These days if I were to do that again I would probably at least try some damping compounds from EAR or 3M (the latter of which makes a very effective epoxy damping compound called 'DP105', which would have to be corralled before it set). Older hons like you see on Altec, Klipsch and the like made out of metal would seem to benefit from this sort of treatment.Not sure i follow , never seen a post worth anything technical from you , all subjective opinionated yada yada parroted from other’s stuff , so i was actually hoping you knew something on how to modify old Altecs.
I have , My own Vitavox CN -191 x 3 S2 early , together with a friend’s CN-191 x 5 S2 early + his later production S2 x 2 mylar , but to a lesser degree… however you will neither believe it , nor even wish to hear it !
Romy Le Chat has a deal to say regarding S2 break-up ( presumably with rising frequency although I don’t recall his being that specific)
I heard Romy‘s five or six way horn assemblage. It had issues. He moved and I don’t think he listens to it much anymore.
