I can’t believe it. For such expensive speaker, they use such cheap plastic speaker binding posts.
Plastic binding post may very well sound better. They do on my Lamm ML2 amps.
If you want to see how one should make binding post, have a look at Gryphon Apex. They are not off the shelf item and it allows one to apply appropriate torque to tighten speaker cable.Do you conclude that from a picture ?
Magico speakers are very well made it could well be anodized aluminium. and then the connector itself from. Copper / copperalloy .
Im sure TLI or rhapsody could /can answer your question
Was listening at KJ west one with the Dart 468s yesterday. Alon presenting. Heard the XVX in the same room with the darts, and heard the new sonus Faber here with Soulution and Zanden
So, what were your impressions/distinctions between the XVX and M7?
Yes I visited too, sounded superb with Helix 2 mkiii turntable, effortlessView attachment 130032
It doesn't surprise me but can you please elaborate?m7 is quite superior to the XVX
When one channel was tuned, the other channel was mirrored with the first one. If the room was asymmetrical, the work has to be repeated for the other channel. The final step was to dial in the toe-in. Started with no toe-in, some degree of toe in was gradually added. Peter settled with each speaker pointing 17 inches away from the sweet spot.
why am I not surprised they preferred to use CD to set up the M7
