Brave !I agree. 5dB per major division is a good compromise and avoids 'too much data' which would obscure the response trend and generally make the graph harder to read. Graphs like I posted can always be clicked upon to see a full size version.
Another suggestion if we're really getting down into the weeds here - and one I'd like to see - is the posting of the original .mdat files from REW which preserves ALL the data, the good the bad and the ugly for those who want to get into the specifics of RT60, distortion, step response, waterfall plots etc. It's all right there in the .mdat file. It's easy enough to do by sharing the file on your Google drive or whatever you may have.
To show how foolish I am, I'll go first. Mine can be downloaded HERE. Note that my subwoofers are set really high in these plots - normally they're much more moderate in level.
I had a look - I am not familiar with REW but that looked like it was not time gated so I presume it includes a fair bit of reverberant info. This has always puzzled me about in room plots - if its long enough to get reliable bass information it is not getting very clean info
I have done ground plane plots at listening position to try and get better bass info and that seems to help a bit by taking out the floor reflection but there is still plenty of them
The REW impulse plot looks different from " normal" - it is hard to see where the reflection points are - I also noticed left and right phase were quite different - I am assuming different reflection points
I quite like a 3 db taper from 1K down to 20K and a bump in the bass of about 5db or so - as you note yours is quite " goosed" in this plot
Do you have have any plans to try and get a more even output - does the speaker measure better in an anechoic type environment ( I measure outside and up in the air for the crossover design but its a big task to haul outside when finished )
Thanks for sharing - its great to see how other folks go about it - I am doing a crossover using convolution filters at the moment and will post when I get down the track a bit ( ie they are half respectable)
Phil
